Question about GE 46GW 948 46" Rear Projection Television
Tv trouble we are having problems with our tv. we lost remote and cannot figure out how to reset. it seems like it is stuck in antannae mode and wont switch to cable. it has to be a setting because a dvd plays fine and we troubleshooted every other possibility including cable box problems.
  • 373 Answers
You must have a RCA or GE remote that has the input button to change back to cable or antenna.
Posted on Jan 02, 2008
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
Polariod P40LCD12 reset
I personally have had the same problem with Universal remotes. The best solution is to buy the correct remote. I would first call the manufacturer to see what they would charge you for a new one. Then ask if they sell refurbished ones. Also check online for an OEM remote. You could probably get one for less than the universal remote.
Jan 04, 2014 | Polaroid Televison & Video
I have got a technika television which is stuck on DVD mode. The remote that i have for it does not work, so i bought a Gemini universal remote to try and solve the problem but the codes provided do not...
Have you tried unplugging the TV for 10 minutes? If not, give that a shot. This will allow the TV to reset itself to factory defaults (usually back into TV mode) so at least you can use your TV while you figure out the remote. There is also a possibility that the TV is stuck trying to read a remote that is lost (for some reason the firmware could be locked up) This would keep your Universal remote from working even with the correct codes. I hope this helps!
May 27, 2011 | Televison & Video
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
Wide screen mode won't go back to "normal".
Was exactly what you said. The cable box settings were in wide mode. Couldn't figure it out at all. Funny thing was too.. on my cable box remote, the button under the #9 button is the # button.. it doesn't say zoom at all.. but it totally controls the zoom.
So thanks for that.. AND thanks for saying "under the #9 on the cable remote" instead of just saying .. the zoom button.
Thanks again!!!
Dec 25, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
Dec 18, 2009 | Sanyo DS27510 27" TV
TV Stuck in VCR mode
I used code 191 for my combo unit
Jul 09, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Dwt 1905 tv stuck in game mode
Comcast universal remote code for dwt 1905 is 0171, just tried it, it works
Nov 26, 2007 | Durabrand DWT1905 TV
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
76 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
