You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 800 Grayscale Copier
I have a Lanier hand held cassette tape recorder model AL/C II.It has a built in mic or you can plug...
(More)
I have a Lanier hand held cassette tape recorder model AL/C II.It has a built in mic or you can plug one into it.It also has place for ear phones, conf.& dict. switch as well as on and off switch.It has counter and battery indicator as well as speed and volume control.
The problem is It will not record or play. I can hear the motor running but nothing moves. It used to be used for investigative purposes for interviews.
I need to get it repaired.
