Question about Hifonics Brutus BX 1505D Car Audio Amplifier
Problem! my power light is off and my protect light as well but im still getting juice because my amp lights up...but when i turn on my car the light coming out the word (hifonics) on my amp is bright then it dims...and i cant get my subs working...i got 2 channels coming from my subs and 4 inputs (- - + +) on my amp but i cant any sounds from my subs.
You have a foulty amp i wtake it bk and change it
Posted on Dec 27, 2007
Hello, i have a nitro bmw 486 amp. i use it to power my 2 subwoofers in my trunk. its a very good amp and sure does its job, but randomly the light will turn red, which means protect, and my subs will shut...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty D .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-lv2kkrmxrai4iihdvw4m3np2-1-0_0.jpg
Jul 31, 2010 | Nitro BMW-486 Car Audio Amplifier
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
Amplifier protect circut is on and wont shut off
ALL AMPS HAVE PROTECTION CURCUITS, U NEED 2 CHECK ALL YOUR WIRES THAT HAVE ANY POWER RUNNING THREW THEM, U PROBLY HAVE A PINCH IN A WIRE CHECK ALL UR CONNECTIONS.
Mar 20, 2009 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Amp wont turn on
New amp sounds messed up... grounds are bad and sometimes the amp tries to draw power but cant... So it immediately goes to protect... All jacked up... Audio specialist could help... Repair shop if local ..
Nov 04, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Hifonics Brutus BX 1505D Car Audio Amplifier Logo
270 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
