Question about Samsung (SRP-270CP) Matrix Printer
Error light i got a samsung srp 270A receipt printer and for no reason i got the error light came up and now it does not print anything i tried to change paper and change the ink but it doesnt work. i checked the cable as weel but no help. it christmas and i cant get a replacement till next week. can anyone help me? i kinna need an answer asap because it actually for my shop. thanks
flopez
  • 161 Answers
SOURCE: Samsung ML-1710P Printer Problem
Most probably you took one of the paper sensors out of place. Any printer technician can happily put it back.
Posted on Sep 22, 2007
SOURCE: SRP-350 barcode CODE 128 C printing problem
I have a samsung printer srp-350pg, it is printing garbiches, I download a driver does the samething, used generic driver but nothing changed
Please help
Posted on Jul 21, 2008
SOURCE: Samsung CLP-300N Laser Printer will not print, etc
We just had a similar problem in my office. Our Captain's printer was giving a solid red light. After replacing all four toner cartridges and disassembling it to look for paper jams, dirty contacts or dirty paper jam sensors I looked at the manual. I noticed something about the waster toner cartridge, which was a problem on another printer that I had fixed before, but I hadn't thought of that option yet. I yanked the waste toner cartridge, which is to the left side of the toner cartridges when looking from the front. It was full.
At this point you have two options: get a new one or clean the old one. Being thrifty and wanting to fix it immediately, I dumped all the old toner out and used long q-tips with alcohol wipes on the end to clean out the sensor windows which the printer uses to sense if it is full or not. THESE NEED TO BE PRISTINE! There is a very thin piece of plastic, that I suspect is an LED light filter, that will also need to be cleaned. This is also inside the waste toner cartridge.
This may or may not be your error, but this fixed it for me.
Bradley Hansen in Seattle
Information Systems Technician, United States Coast Guard
Posted on Jul 22, 2008
SOURCE: Driver for srp-270ap
i need driver xp for samsung receipt printer srp-270ap
Posted on Nov 03, 2008
Corwin7
SOURCE: Linux drivers for Samsung SRP 350 Plus Thermal Printer
This was originally a Samsung printer, and they had plans to release a Linux driver. However after some corporate games it's now owned by Bixolon, and everything Linux has been axed.
Posted on Apr 28, 2009
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have developed an ms access POS. When i print receipt to samung thermal printer srp 350 ver 2, it prints very slow. i have tried several drivers but i end up with the same slow printing problem. I am...
itecghana, printing slow is probably an issue of the interface type (serial, parallel, usb, ethernet...) and not the printer itself. The Bixolon 350 has a self test printout capability (turn on printer while holding down the feed button) which'll demonstrate the print speed capability of the printer.
My guess is you have a serial interface (COM port), serial is notoriously slow when printing via any windows driver.
If the printer you have is a 350, one solution is to change the interface card on the printer from Serial to USB. The part number of the USB interface card is IFA-U Type, can buy one for about 35 bucks online.
Jan 10, 2011 | Samsung SRP 350 Thermal Printer
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
My bixolon samsung srp 350plus printer will not feed paper when i go to run the test on it it just cuts the top of the paper then paper out light comes on any ideas?
Try to push just the FEED button. if it doesnt feed, call their service center. hope it is in warranty still.
Problem could have happened with a power surge
Jan 11, 2010 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Theo
fix all connections again. call ur vendor.
Sep 05, 2009 | Samsung SRP 270A Matrix Printer
Oct 24, 2008 | Samsung SRP 270AP Matrix Printer
SRP 270 feed 10 cm of paper before printing
Does this happen with all applications? This may be due to the header/footer and margin settings in y our application. You can try opening notepad (Start -> Run -> Accessories -> Notepad) and entering a bunch of text into it. Then print it up and see if there is still all the extra space. If it prints normally, then adjust the margins in your other applications. If it is still not operating correctly, try running the printer diagnostics program to re-calibrate the printer. http://www.samsung.com/support/index.asp
Sep 19, 2006 | Samsung SRP 270C Matrix Printer
Samsung (SRP-270CP) Matrix Printer Logo
143 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
