Hello, I assume yoy know how to define your matrix, but I will repeat it here for others who might not know. You can skip to Calculation 1.Turn Calculator ON. If there are no icons, press [MENU]. Data Entry 2.Use arrows to highlight [MAT] icon. Press [ENTER] 3.Highlight the first line where it says Mat A. Use the right arrow to enter the dimensions of Matrix A. Enter 3 and press [EXE]. The cursor moves to the second dimension. Press 3 and press [ENTER]. 4. The matrix entry screen appears. 5. Enter first matrix coefficient a_11 and press [ENTER] 6. Enter a_12 and [ENTER] ..... Key in last coefficient a_33 and press [ENTER]
Calculation Press [MENU] and [RUN] Press [OPTN][F2:MAT][F3:Det] Command echoes on screen as det Press [F1:Mat] echoes on screen as Mat; screen shows det Mat Press [ALPHA] A The screen displays det Mat A Press [ENTER] to calculate the determinant.
If the matrix is not square, you cannot calculate its determinant.
Hope it helps..
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you so much! You are awesome!!!
" - casaconlonaz
Popular Solutions for Casio FX-9750GPlus Calculator
FX9750 GA plus got wet and we tried to dry the parts inside carefully, but after we replaced the...
(More)
FX9750 GA plus got wet and we tried to dry the parts inside carefully, but after we replaced the battery and got dried up, the calculator doesn't turn on anymore. Can I still troubleshoot this graphing calculator?
