hello, if you have a blinking light this means theres a voltage drop or failure causing a circut fault some where inside, you need to find a service manual for your set or have it checked out by a tech. there are high voltages and live circuts inside so if your attempting a fix on your own be aware of this and get a service manual it will tell you according to the blinks whats the trouble or what part to replace or service. hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
it was due to a tree falling over a power line,it took 2 days to get fixed.every thing is all good now.thanx
" - tykodar
19 inch flat screeen would not stay turned off--turned itself baack on Unplugged overnight and nest...
(More)
19 inch flat screeen would not stay turned off--turned itself baack on Unplugged overnight and nest day would turn itself off when changing volume or channel. Unplugged overnight and today is ok for now. What to do?
runs fine for 2 hours then picture quality changes, no controls will work, cannot turn off the set,...
(More)
runs fine for 2 hours then picture quality changes, no controls will work, cannot turn off the set, it turns itself off later. next day it turns on works fine for 2 hours, same problem returns
