Question about Compaq Presario 5000 PC Desktop
Connect laptop to cpu and use laptop as monitor
Mi computer is a dell inspiron
  • caoscol Dec 29, 2007
    thanks for you help , we are in contact.bye
  • Anonymous Aug 22, 2008
    i hva a laptop . i hav some data in my cpu also.. wanna transfer data to laptop from cpu i.e., i use laptop jus a monitor and connect my cpu to that .. how can it be possible.. pls answer
  • 625 Answers
Go to "tiger direct" and purchase a usb to usb interconnect cord. the software they supply will install an ansi and unicode driver so you can use two machines with win xp, win me or win 98. xp and me use the unicode driver while win 98 uses the ansi driver.
Posted on Dec 28, 2007
Did I have an issue with the Dell Monitor that I set up wrong way and what went wrong with it?
Your Inspiron laptop can output video:
* only to the internal screen
* only to the external screen
* to both internal and external screens
You need to "tell" your laptop to send the video-output to the 2nd or 3rd modes, above.
Usually, hold down the 'FN' ("function") key on the keyboard, and press one of the F1-to-F12 keys -- the one that has the "outline" of a computer-screen. Press the key more than once to "cycle" through the above 3 modes.
Jan 22, 2015 | Dell Computers & Internet
Dell 1703fpi
Dell 1703fpi LCD monitor,
I got that part Dan.........
What I need is what Model Number of Dell Inspiron it is.
This is on the Bottom of the Inspiron laptop.
Because I do not know if the Dell Inspiron laptop you have, has a DVI port, or a VGA port; for an external monitor......
Generic information while I wait.........
Example of Digital Visual Interface port, and corresponding cable,
Example of Video Graphics Array port,
Can be on the side, or back of laptop.
Laptop OFF, monitor OFF, connect the matching video cable from the external monitor; to the laptop.
Now turn the laptop on.....
By factory default settings, the display should now show on the external monitor. (Dell 1703fpi)
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold down on the Fn key. (Usually 2nd key from left on bottom row of keyboard)
AT THE SAME time tap once on the Display Toggle-Over key.
Which one is that? Dunno.
Laptop model number was not stated.
For a Dell Inspiron though, it's usually the F8 key.
(F1 through F12 keys at the top of the keyboard)
Hold the Fn key down, and at the same time tap once on the F8 key.
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
IF, F8 is the correct key for Display Toggle-Over, and there is no display on the external Dell 1703fpi; then I suggest you have a problem with the video chipset; on the motherboard.......
Awaiting reply in a Comment.
Jul 03, 2013 | Computers & Internet
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
May 11, 2012 | Dell E207WFP LCD Monitor
Dell 2000-0123
To resolve this issue, update the BIOS on your Dell Inspiron to revision A13 or later. This BIOS is available on Dell's support Web page.
To work around this issue, change the display setting in your computer BIOS to LCD instead of SIMUL. Also, you may be able to connect an external monitor to the VGA port on the laptop. For information about changing this setting, refer to the documentation included with your computer.
Apr 21, 2012 | Dell Inspiron 7500 Notebook
Want to connect my Dell laptop to my ViewSonic monitor-help!
Just connect the VGA 15 pin cable from the monitor to the VGA port on the laptop.
Turn on the monitor then the computer.
Hopefully Windows will find new hardware and ask you to run the multiple display wizard.
If the external display doesn't automatically turn on then you need to hit a keystroke combination. FN+ the key on the top row that has an icon that looks like a picture of a monitor. Usually an F key.
This keystroke combination switches between LCD, external Monitor and both.
When you get video on the external monitor, then you can get into the display control panel and change the resolutions and display modes to your liking!
Jul 06, 2010 | Dell Inspiron B130 Notebook
Have 21 inch monitor dell st2210,mi problem is everythink desapere from the screen and later come back,lock picture is in the center of the monitor al the time i have 1 year waranty i call dell speak to...
Connect the monitor to some different computer, e.g., a laptop, to verify that the monitor is working.
If not, take it back to DELL/STAPLES, and get them to check it out, or to exercise the "warranty" to get it repaired/replaced.
May 14, 2010 | Dell ST2210 21" Monitor
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system:
Feb 04, 2009 | Dell Inspiron 9100 Notebook
Dell Inspiron 8200 ATI Mobility Radeon 9000 Green Screen Problem
Try connecting an external monitor to the laptop. After your computer is attached to an external monitor, press the <Fn> key and the <F8> (CRT, LCD) key to switch the video image to the display. If the external monitor works, the computer display or video controller may be defective.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 8200 ATI 64MB Video Card -...
Compaq Presario 5000 PC Desktop Logo
676 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
