Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Cable Connection Problem
I just got my TV and its 52" and when i hooked up HD ready comcast tv will turn itself on about every 20-30 minutes....someone told me to reset the tv settings....where are they? and is this the correct corse of action?
  • 4,402 Answers
I would suspect the setup of the Comcast STB. I assume it's Motorola. You need to set the output format for HD to 1080i and the 4:3 override to 480i. See:
There is a user convergence that you can do - instructions in the operating manual typically right after the section on Magic Focus, or you can do a DCAM convergence:
See also:
Posted on Jan 04, 2008
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Audio cuts out intermittently and tv only 10 months old.
Hook the tv up without the box then use dvd etc to test the sound
If the sound works find with dvd etc hooked up then its the box
Jan 20, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Hd hook up for rca 52"dlp
If you have Direct TV HD the best way is to use a HDMI to DVI cable. If you only have the component (red/green/blue)connectors on the Direct TV Box that would be the best way. You will not have audio using the DVI cable, so you will have to run Red/White cable to the Audio Input.
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
May have wrong diplexer. Ground potential between box and TV may cause problems. Cable techs should check to see if slitter is right
Apr 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Please help snowy/ fuzzy picture
If you can move the TV to a known good working cable feed and connect it there. if the picture looks normal then most likely you have a bad splitter, a bad fitting or even a bad cable box on that TV.
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
