Home | Dell | 942 All-In-One InkJet Printer | Dell all-in-one 942 pri...
Dell 942 All-In-One InkJet Printer
Problem for Dell 942 All-In-One InkJet Printer
Dell all-in-one 942 printer
By tnstiger00 on Oct 14, 2009
My Dell all-in-one 942 printer is not communicating with my dell laptop (inspiron 600m). I have unplugged power and usb cords. what else can I do to fix this problem?
Solution #1
posted on Oct 19, 2009
Not Rated)
john_yap
Rank: Guru  Dell StaffDell Staff
Rating: 97%, 54 votes
hi tnstiger00,
you can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
just update me if you're still having issues with the printer.
Was this helpful?
Yes
No
Popular Solutions for Dell 942 All-In-One InkJet
Questions and Unsolved Problems for Dell 942 All-In-One InkJet
Do you recommend Dell 942 All-In-One InkJet Printer?
Answer
Answer
Have refilled Dell black cartridge but the printer will not print with black this time. Any help... (More)
Answer
how to get rid of dark smudges on copies , printer works fine?
Answer
driver s/ware will not d/load to my laptop.Dell aio 942.Dell site no help,.Was already installed but... (More)
Answer
My dell 942 AIO printer will not accept the new black cartridge I have installed. Still gives... (More)
Answer
Dell 942 printer won't recognise black cartridge: "install lh cartridge" I have just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell 942 All-In-One InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
