Bausch and Lomb Professional 200  Telescope
Problem for Bausch and Lomb Professional 200 (200 x 114mm) Telescope
Cant see out of 49114500 telescope
By dougalls on Dec 27, 2007
got tasco 49114500 telescope and has no details on how the eye pieces work, I can see some things like trees and hills with the large eye piece but the two smaller one I cant see a thing how do I fit /use them,
Same Problem
Dec 27, 2008
-   new zhumell 114 reflector scope, i cant see anything, not even light through the scope. Each eye piece works individually, but not together. Do i have to have complete darkness and focus on a distant light? this is so frustrating. -   2scope
Nov 16, 2008
-   got tasco 49114500 telescope and has no details on how the eye pieces work, I can see some things like trees and hills with the large eye piece but the two smaller one I cant see a thing how do I fit /use them-   Guest
Apr 20, 2008
-   I just bought a Meade ng-60 at a garage sale. I can't see a thing. All I get is white, like I'm looking at white posterboard. No images. Nothing. I've removed and looked at the eye-pieces. I've looked down the tube without the eye-pieces and can see the object through the lens at the far end of the optical tube. It must be in the eye-pieces.-   notrac
Best Solution
posted on Jan 01, 2008
Helpful)
Science Guy
Rank: Guide
Rating: 90%, 53 votes
You're on the right track since you can see something with the large eyepiece. The smaller ones will work the same basic way, but only for objects that are farther away. When you use a smaller eyepiece, the magnification goes up, and usually, the higher power eyepieces may not work for close objects.
Try looking thru the middle size eyepiece at a very distant big object, that is much further away, like at least 1/4 or 1/2 mile, in daytime. Try adjusting thru the entire adjustment range slowly, and at some point, you should see the image appear, and sharpen up.
The middle eyepiece will be typically be harder to focus easily, since the focus range is smaller. Likewise, the smallest eyepiece will be even touchier, but its the same process. Just turn the adjustment knob slowly.
It also helps sometimes to hang a weight like a book from the center of the telescope or tripod to help stabilize everything.
All of this will be easier in the daytime first to get practise, and to learn how careful you have to be. Good Luck.
Was this helpful?
Yes
No
Solution #2
posted on Jan 11, 2009
Not Rated)
Joe L
Rank: Guru  Binoculars & Telescopes  Expert
Rating: 89%, 247 votes
Here is a beginner's instruction on different types of telescopes--
http://www.uk-telescopes.co.uk/beginners_guide%20to%20telescopes.htm
Yes I know the box said 650 power but that was a BIG BIG lie-- the smaller the number on the eyepiece the more magnification. Do NOT use the 2x barlow which doubles the normal eyepiece power in these small telescopes--- just way to much magnification. This is NOT necessary to view the sky at night. I almost NEVER go over 100 power in my 8 inch telescope-- once in a while maybe 175 power. Sp use the eyepiece with the largest number on it--- to practice focusing during the daytime.
Try to locate a local Astronomy club and attend one of their star parties and ask questions. You can bring the telescope with you and they will help you with it.
Was this helpful?
Yes
No
Popular Solutions for Bausch and Lomb Professional
Questions and Unsolved Problems for Bausch and Lomb Professional
Do you recommend Bausch and Lomb Professional 200 (200 x 114mm) Telescope?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or... (More)
Answer
Hi looking for an instruction manual for the Bausch & Lomb Professional 200. Thanks
Answer
I would like to find an instruction manual for this telescope. Any ideas where to look? Want to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Telescopes Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
