Question about Kenwood KDC-X590 CD Player
Powered Subwoofer won't work
My powered subwoofer won't work. It used to put out sound and turn on fine, but then it started to go in and out depending on its mood. Now it puts out no sound, and does not turn on. I have ruled out wiring. I have ruled out the subwoofer "ON" setting on the deck. I have ruled out a problem with the powered sub. What would cause it to go in and out from day to day and then suddenly stop working altogether? My deck also has problems with its display. It also went in and out for awhile and then finally quit. I still get sound from my speakers, and everything functions normally, (except for the powered sub). I don't think the problems are related but maybe they are?
  • dkweaver7 Jan 10, 2009
    My khl8120 subwoofer will not produce sound. It has worked in the past. It is hooked to a sony strde 875 receiver. Connections are from subwoofer audio output to R rca low input. Power light is on, switch is on normal.
  • 1,512 Answers
This problem has many causes... but try this one... often when a faulty subwoofer speaker is to blame this test will tell you. Connect another speaker(any speaker) temp to check if there is audio still to the sub. Keep the levels down to ensure you dont go on a trail of destruction.
The spider wires from terminals on the speaker to the cone may be intermittent. I have seen this a lot on all types and makes of subwoofer driver!! This a common failure and can often be detected by tapping the speaker cone when it does the cut out thing. If it starts up, and they often do..., then you probably have intermittent spider wiring to the cone. A GOOD “Hi Fi speaker repair dood” can help here and replace the spider wires for you and save the expense of replacing the driver.
This is just one solution to the problem you are having.... there are many more..... and you should try this FixYa and see what happens. If you cant tell WTF then hit me back up here again. I work WITH YOU, to get the problem out for you.
If it sorted what you suspected... then rate me !FixYa!!.... Thanx
Posted on Dec 28, 2007
I have this same problem
Posted on Apr 22, 2008
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
Powered subwoofer amp repair? On and off works fine.. very weak signal to sub. All wires checked and working fine.
For starters, it is a home theater in a box. With that being said, highly consider upgrading before spending more money on the system. If thats not even an option, have you tried adjusting the level of signal being sent from the receiver out to the sub? It sounds stupid, but this is often over looked and can sometimes be tricky depending upon the type of receiver you are using, to adjust the level being sent to the sub... Typically when a subwoofer has little to no sound, this is the issue. Also, is the sub powered (does it have its own amplification using a power cord that plugs into an electrical outlet? If so, does it have a volume knob on the back, and does it respond when turning the knob? If its not powered, than your problem is what I described above, unless you've already done that. If that is the case, your speaker is fried... Hope this helps
Jun 19, 2014 | Cerwin Vega CMX 5.1 Home Theater Package...
Subwoofer not working
The subwoofer is dependent on a sound amp powered by an external source whereby the speakers are powered by the line output from the sound source (like a computer speaker out jack). Powered Subwoofers controlled by a power amplifier require a power source such as an AC/DC source plugged into the house power. If the device is defective or a mismatch, the subwoofer will not function. Try a new power transformer and see if that fixes the problem. Other than that, if the power transformer is good, then the woofer could be defective.
Jan 13, 2014 | MA Audio MA5137 700 Watt 5.1 Home Theater...
Why won't my powered subwoofer turn on? It's not
Have you check if the plug is good on it?
Dec 03, 2012 | Audio Players & Recorders
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenter™ SW 200 with Clean Power™ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
Kenwood KDC-X590 CD Player Logo
2,770 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
