Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Yellow A/V cable port
I am using a video game system on this TV and today we are having a problem with getting a picture. I think the cable port might be loose because when you press down a bit on the yellow cable, the picture then flicks on, but as soon as you let it go, you loose the picture again.
Wondering if there is a way to replace the port itself? Or is this something that would need to be serviced ?
  • 29 Answers
What happens often is the connector comes unsoldered. When the TVs are built the temperature is kept low to keep from buring out the chips on the board, but larger metal things dont always get enough solder. They are also under stress from outside. I have fixed this dozens of times. It involves opening the TV, gaining access the bottom of the circuit board with the connector, and resoldering it. I would suggest someone good with a screwdriver and soldering iron to do the work.
Posted on Feb 02, 2008
I have set up my wii I have sound but no picture
Hi, What connections are you using? Do your cables have White, Yellow and Red ends? If so make sure that they are connected to the correct ports on your TV, or that they are connected to the correct ports on the SCART adapter on the end of the cable.
Also if you have no Yellow port on your TV, then insert the Yellow cable into the Green 'Y' port, this could be the problem. Here is the Nintendo help page.
Hope this helps.
May 25, 2011 | Nintendo Video Game Consoles & Games
I am trying to hook my wii to my Onkyo receiver. The Plasma is a Pioneer and you can't hook the Wii directly to it. I have the yellow, white, red cable that comes with the Wii.
Hello Julie
Thank you for using Fixya!!
OK, this is actually very easy once you get the hang of it:
The Yellow, Red and white cable you have, is actually the Video(Yellow) and the 2 stereo Audio cables(Red and White).
Now, the Yellow wire goes into the video port on the gaming unit, and into the Video input port on the TV itself. This is usually The AV channel's port.
The white and Red cable goes into the audio port on the gaming console, and into the audio in or AUX port on the receiver.
This should do the trick, but you will need to remember the following:
Once you want to use the gaming device, you should set the TV on the AV channel, n=and the receiver on the AUX channel.
Feel free to let me know if yu need any further assistance.
Kind regards
Lock123
Feb 20, 2011 | Onkyo TX-SR608 Receiver
How do I plug in a game system?
If you have HDMI port on the game system and a free HDMI port on the TV plug it into that and use your TV remote and select source/input HDMI 1 or 2. normally your TV is using HDMI 1. Second optin if you are not using HDMI cable the you need to use audio/video cables red,white and yellow cables hook them up colors matching on game consloe and TV. Try that !!! TV make and models varies. Good Luck
Feb 04, 2011 | Televison & Video
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How to connect nintedo to plasma tv
Hi,things you will need,
  • Video game console
  • HDMI cable
  • Audio/visual cable.
  1. Plug in your video game console's power source.
  2. Connect one end of the game console's audio/visual cable into the corresponding slot on the console if you have an older game console. If you have a newer console, insert one end of an HDMI cable into your console's "HDMI OUT" port.
  3. Plug the red and white ends of the audio/visual cable into the corresponding red and white audio inputs located on the back of your Vizio plasma TV if you have an older game console. Plug the yellow cable into the yellow "Video In" input. Depending on which model of Vizio TV you have, the yellow input may be located either right next to the audio inputs or it could be located a few ports away.
  4. Plug an HDMI cable into one of your TV's "HDMI IN" ports, if you have a newer console.
  5. Turn on your video game console and your Vizio plasma TV. Press the "TV/VIDEO" button on your remote to cycle through the various inputs. You should eventually get to an input that's displaying your video game console's home screen.
I think that will do.
Have nice day.
Sep 25, 2010 | Nintendo Video Game Consoles & Games
We just got time warner cable and the DVR was also installed yesterday. We bought the DVD today and connected the cables as directed by color but we hear the DVD running but no picture comes up when the...
try another input,the yellow port is your video port.take the red wire and put on the yellow
port to see if you have a bad cable.if this does
not work connect r
the dvd to another tv. match the yellow to yellow for video
Aug 12, 2009 | GPX D1816 DVD Player
PSP 6 pin gen 2 cable not working on tv?
you have the wrong cable. the cable you have is for HDTV's only.
by the ports on the TV, you have a standard TV.
The cable's colors are Red, Blue, Green, Red, and White. If you have a HDTV or these ports on the back of the TV, connect them like in the picture.
from what you said, it seems like your TV's port colors are Yellow, Red and White. If you only have these ports on the back (Yellow, red, white), you need this cable:
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Get sound but no picture
Plug the yellow RCA cable into the Video Out on the 3 2 1 and into one of the Video In ports on the tv. Make a note of which port you plugged into. Then change the input selector to that video port on the tv.
Feb 16, 2008 | Bose 3 2 1 GSX System
No DVD picture while playing Panasonic SC-HT920
You should connect your Video cable from DVD to TV's Yellow pin. Then you must first select whether its AV1 or AV2 from remote control. Then you'r done!
Dec 09, 2007 | Audio Players & Recorders
Video Input
Are you sure that the source is generating a video signal? It is extremely rare for both front and rear Video Input sockets to fail simultaneoisly. from your description, i would suspect the cable connecting the Viseo out of your DVD player / Video Game than the Video Input ports of the TV. If you have another cable, just try again with that. Or, try using the Red to red cable into the Yellow port, using one end at the DVD player and the other at the TV Video Input. If there is image, then it is confirmed that the cable is faulty, and you can get a replacement cable for a few bucks at any Video store.
Mar 20, 2007 | Symphonic ST419E TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
