Hitachi 43FWX20B 43 in. Rear Projection Television
Problem for Hitachi 43FWX20B 43 in. Rear Projection Television
The color and focus is off
By tom1501 on Oct 14, 2009
Comments:
Oct 14, 2009
- 3D and purple and green
Clarification Request
Posted by SD Tech on Oct 14, 2009
Does picture look 3d? red or blue out of place?
Best Solution
posted on Oct 14, 2009
Very Helpful)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 1033 votes
OK--for a Hitachi this set is a little unusual---it uses two of the STK-392-120 CONVERGENCE CHIPS.
One or both are bad(usually just one) You need to replace both and any discolored resistors around them--all the resistors have location numbers and if any are even slightly discolored you need to replace them and both chips---You can buy a pair of these chips on Ebay for less than 13 dollars plus shipping.
If you remove the back cover (unplug the set first!) look at the circuit board on the far right side----about 4 inches wide and about 12 inches deep---the chips are on the far right side on the large metal piece with fins.
If you look and find any of the resistors behind them (on the left side of the metal with fins) discolored---note the location number printed on top of the circuit board under them (RK46 etc) and I can tell you the exact value of that part--most of the resistors that fail are low value and can be tested just like a fuse--It is important to find any bad resistors as if you replace the chips and miss any open resistors the set will still have the same problem.
THIS IS A EASY SET TO DO THIS REPAIR ON IF YOU KNOW HOW TO SOLDER---I CAN GIVE YOU INSTRUCTIONS IF YOU NEED THEM.
THIS KIND OF REPAIR TAKES ABOUT 1 HOUR--THEN YOU ADJUST THE SET WITH THE ORIGINAL REMOTE--set should be good to go without having this trouble for 5-8 years.
Let me know if this information helps you---If you are not able to do the repair let me know and I will give you advice
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hitachi 43FWX20B 43 in. Rear
Questions and Unsolved Problems for Hitachi 43FWX20B 43 in. Rear
Do you recommend Hitachi 43FWX20B 43 in. Rear Projection Television?
Answer
Answer
the screen on our Hitachi is speckeled with blue dots why is this happening?
Answer
Hitachi 43FWX20 43 in rear projection TV 2002 red and green shadows on sceen. Sometimes powering off... (More)
Answer
The TV comes on and the red light next to the power button lights up then instantly turns back off... (More)
Answer
hitachi 43FWX20B 43in. rear projection has green streaks and spots on the plastic screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
