Question about Motorola Mobility RAZR V3
No Ringtones When someone calls,The phone vibrates and will not ring. Also, I cannot play any ringtones in multimedia sounds.
  • flabulous Dec 27, 2007
    Phone only vibrates does not ring.  Just bought it.
  • 263 Answers
Thats probably because you have that one set for airplain so the only way to fix it is to go to menu , tools., sound , and you shoud see speaker or airplaine option there is a check mark on wich you have you preference settings just change an thats it
Posted on Dec 27, 2007
How can I make my speakerphone work again?
call someone or tun on music on phone menu select loud
Feb 27, 2016 | Cell Phones
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    LG EnV3 ringer volume is LOUD even when set to LOW
    I have the same issue. I know this is a roundabout solution, but I love the phone in all other ways, so I handled it like this:
    I make my own ringtones with audio editing software anyway, so I just made versions of my original ringtones that were "volume-cut" by 6dB or 12 dB. Then to get these .mp3 files installed as ringtones, first I save them to the "my_sounds" directory on the micro-SD card (either via USB cable and "USB Mass Storage" mode, or by taking the card out and plugging it into my PC with an SD card adapter,)
    This puts them in as "sounds" but not yet ringtones. Then, on the phone itself, I send a multimedia message of each sound to myself (i.e. to this same phone, "from me to me") Once each message is received, you will get an option to "Save as Ringtone", and once you do that, the sounds become available as ringtones.
    I just use ALL of my own "volume-cut" ringtones for the different ring sounds in my phone, and it makes it quieter. Note that if you then use any "standard" ringtones, they will seem particularly loud by comparison.
    Oct 05, 2009 | LG enV3 VX9200 Cell Phone
    Samsung i616, Ringtone file corrupted
    Best way I have found is to use explorer and browse into your mobile device and search for a folder called "volatile". I copied every wierd looking folder that started with XME or such. There were like 999 of them on my phone. Once they were removed, everything went back to normal!
    Mar 13, 2009 | Samsung BlackJack Smartphone
    No ring, only vibrate
    if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
    May 02, 2008 | Nokia 6288 Cellular Phone
    Ringtone will not work
    Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
    Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Ringtone/Ringtone "PLAY" function not working
    crazzyyy problem...
    i suggest take it back wherever you got it!
    Nov 07, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
    hi, before applying tone, play it & listen, if it plays sound. Resent ur mobiles master setting & apply now. bye
    Oct 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    No sound when phone rings
    I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
    Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    Will not ring or vibrate.
    Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
    Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
    Motorola Mobility RAZR V3 Logo
    96 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
