Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Printing envelopes on the bizhub 252
How do I print legal size envelopes on bizhub 252?
  • 1 more comment
  • Anonymous Oct 24, 2008
    WHEN I GO TO PRINT 4 1/8 X 9 1/2 ENVELOPES ON MY BIZHUB 200 IT TELLS ME THAT THERE IS NO MATCHING PAPER FOUND.WHEN I DO HAVE THE ENVELOPES ON THE BYPASS TRAY FACEING UP? I THINK IT HAS SOMETHING TO DO WITH MY SETTINGS BUT NOT SURE?
  • vicki435lewi Nov 07, 2008
    I am not able to print envelopes from my computer to the bizhub 250 using the by pass tray. Does anyone have any ideas?
  • familyforce6 Jan 27, 2009
    Having the same issue. I've tried changing print properties from landscape to portrait, selecting envelope size. Any help would be appreciated.
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
Posted on Jan 27, 2009
  • 167 Answers
Custom size, use the bypass tray and run them FACE UP. If you can even open the flap. The media weight will be important, there should be an envelope setting but this may not work with the custom size.
Posted on Jan 08, 2008
Print envelopes 350
was the computer os updated, 8.1 to 10 or ?????
try this
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 20, 2014 | Konica Minolta bizhub C351 All-In-One...
Printing on A7 envelopes using Bizhub C253
does A7 show up on the as a option on the manual bypass does it show up in your printer properties??? if not measure the envelope and tell the copier with and length try that option
Nov 21, 2013 | Konica Minolta bizhub Office Equipment &...
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Mac computer. I can't choose to print an envelope and use the bypass tray at the same time. So how do I print an envelope?
on the copier insert the envelope face down
under customer size settings for the bypass enter the size of the envelope # 10 envelope is the biggest you can select select the application you are using and make the correct selections for envelopes in the application
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
Dec 12, 2007 | Minolta bizhub 200 All-In-One Printer
PRINT ENVELOPES
You MUST use the bypass tray and bve sure to enter the custom size, media type and weight in the driver. The settings MUST be set the same on the 180 before printing.
Running envelopes is a tricky situation, but once mastered it should work. Note that not all envelopes will run, try different sizes and brands and keep the ones that work.
Nov 16, 2007 | Konica Minolta bizhub 180 All-In-One...
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Nov 13, 2007 | Office Equipment & Supplies
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
2,797 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
