Question about Toshiba Satellite P205-S6287 Notebook PC
My screen is functioning but the picture is turned 90 degrees
I have to turn my head sideways to read my screen becuase the picture part of my screen is rotated 90 degrees and i have no idea what to do i got this computer a couple of days ago and it happened in the middle of a game i was playing
  • kmhdcdance Dec 27, 2007
    i fixed this one myself too.
  • 689 Answers
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Posted on Jan 29, 2008
I tried "system restore" to the previous day, and it worked. I have Windows XP. Just do a search for the file, click on it, then set your restoration date to the day before. It worked!
Posted on Aug 04, 2010
    Genius:
  • 1,601 Answers
Thanks for the update
Posted on Dec 29, 2007
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
My screen turned sideways
go to Control panel, and find Graphics / Video icon e.g. Intel, Nvidia etc.. There is an option to rotate 90 degrees clockwise or counterclockwise. Select that setting until your screen is turned in a normal way..
Aug 07, 2011 | HP Mini 1000 Netbook
When i move the spout sideways, the whole fixture turns instead
You need to tighten retaining nut on the underside of sink. You will probably need someone to hold faucet steady while you tighten nut. Yom may be able to use channel lock pliersor adjustable wrench. They can be hard to get to as there is not much room. If you have to you can get a basin wrench at most hardware stores. Usually around $15.00. The head will turn from 90 degrees on one side to 90 degrees on other. To use turn head so that open end of jaws are pointing to your right if you are laying on your back under sink.Open jaws and put around retaing nut and turn counterclockwise. This will tighten jaws around nut and you should be able to tighten nut. If you need to you can apply penetrating fluid on threads and get it to tighten. Hope this helps. Thanks
Nov 14, 2010 | Kohler K-10416-BN Fort½ Single Control...
I need the head bolt torque settings can anyone help
2.4L and 2.7L is:
Step 1- 29 ft.lbs.
Step 2- 90 degree turn
Step 3- 90 degree turn
3.4L is:
Step 1- 27 ft.lbs.
Step 2- 33 ft.lbs.
Step 4- 90 degree turn
4.5L is:
Step 1- 27 ft.lbs.
Oct 12, 2009 | 1996 Toyota 4Runner
Torque setings for cylinder head on t25 16d camper
It depends on the bolt type.
6pt bolt head (m11) - 1st 35 ft-lb, 2nd 50 then 3rd 65. warm engine and re-check at 65. After 1000 miles turn 90-degrees.
12pt (m12) 1st 29 lb-ft, 2nd 43, 3rd turn 90-degrees, 4th turn 90-degrees, warm engine and turn another 90-degrees. After 1000 miles turn ANOTHER 90-degrees.
Aug 30, 2009 | 1986 Volkswagen Wagon Camper
My screen has suddenly turned 90 degrees to the right how do i fx
You may want to look into your video card settings about that. Most intel video card has that feature. You should be able to press the CTRL button and the LEFT button to change it. If thats not it then look into the control panel.
Apr 22, 2009 | Computers & Internet
Screen rotation
there is an icon for your screen setup on the tray.
right click on it. an option will be there in pop-up appeared for rotation. Select the right choice.. n njoy.....
thanks
iqbal
Mar 30, 2008 | Toshiba Satellite A100-S8111TD Notebook
LAPTOP PROBLEM
hold down alt & ctrl keys and press the up arrow and that should sort it out
Mar 16, 2008 | Computers & Internet
Toshiba Satellite P205-S6287 Notebook PC Logo
461 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
