Question about Kenmore 24 in. 16022 Built-in Dishwasher
Leaking water on floor in front of dishwasher
Dishwasher leaks water on floor each time we run it. The insulation is also wet.
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
Dishwasher leaking
Clean the float...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 23, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Dishwasher is leaking
If the unit has a removable lower front panel, take it off and slide a sheet of news print under the machine so that the leak will show as a wet spot on the paper. This gives you a clue as to the location of the leak. That position will lead you to a leaking hose, pump, inlet solenoid valve, door seal, and so on. Hope this helps!
Mar 19, 2010 | Dishwashers
Kenmore Dishwasher 17372 is leaking water through tub water inlet
Leaking Dishwasher
heatman101
wqeyrad
Jan 07, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Dishwasher is leaking water. Water is puddling
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Sep 25, 2009 | GE Dishwashers
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher Leak
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Feb 27, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher leaking on floor
Leaking Dishwasher
heatman101
wata
Feb 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher leaks
If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. Also make sure the dishwasher is sitting level (you can adjust the front feet up or down and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Kenmore 24 in. 16022 Built-in Dishwasher Logo
1,157 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
