Question about Aluratek AHDU350500 500 GB USB 2.0 Hard Drive
Aluratek 500g harddrive
I get this error when I'm trying to backup my files 1143790540jtun_en60329009.m25.full cannot read from the source file or disk
but I can copy and paste files over to the external hard drive
Can anyone help me?
  • 44 Answers
SOURCE: Aluratek 500 GB Hard Drive Troubleshooting
I take it from what your saying, this is a brand new hard drive.. if so it simply means that before you can use the drive.. simply click on start, the right click on my computer and go to manage. next, click on storag and then disk management local... right click on the new drive and go to format!
hope you manage okay!
Posted on Dec 26, 2007
SOURCE: Trying to install FreeAgent GO 500G as backup for Server 2003
Installation isn't possible directly from the Harddisk.
Try download from
Good Luck.
Posted on Jun 20, 2009
  • 3051 Answers
SOURCE: Disk spins but clicks and Monitor won't
Hello there:
the external drive is just like a internal drive
It has several platters that look like cd roms they are stacked on top of each other
there is a very small arp that has a sensor at the end of the arm this arm moves along the disk or platter as we call it and it reads the information
When you are hearing the clicking this means that the sensor on the arm cant read any of the information so it goes to the end of the platter and hits the stop and it returns to the beginning and does it again.
After several attempts of reading informatin on the platter it informs the user of the external harddrive error
this usuallu hapens if the drive has been tapped too hard or hit or dropped by mistake and smoking is a big cause of this not to work
these are delicate devices and if they break they generally are replaced ok so i hope that this is verry helpfull for you to understand
best regards michael
Posted on Oct 25, 2009
  • 199 Answers
SOURCE: why i cannot direct copy my files to buffalo
Hello there!
The reason why you cant print your documents straight from your external drive is because the printer software was installed on your PC and thats were its active ie the CPU can give a comand easily.
Good luck
Posted on Nov 03, 2009
  • 4 Answers
SOURCE: My Simpletech 500g external harddrive makes weird
See Be sure to back up everything you need asap!
Posted on Mar 02, 2010
  • 2049 Answers
SOURCE: Why can't I access anything that was copied onto
It is very possible the voltage on your computer's USB port is not handling the load. I would buy a "powered" USB 2.0 hub, plug it into your computer's usb port and plug the harddrive into the powered hub.
Posted on Apr 18, 2010
0 characters
1 Points
Tried to run a full system backup with FreeAgent Go. Backup failed and it looks like some files and programs were deleted from my computer in the process.
Unless you asked the backup program to delete files it won't. The program may have deleted some files it created for its own use.
What error code did it give for failing the back up. How do you know you need the deleted files?
Mar 17, 2014 | Hard Drives
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
Cannot Copy File:Data error (cyclic redundancy check).
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 250g external appears to have corrupted data. windows says it fixed the errors but my last two attempts to back up my computer failed. How do I fix the external drive?
> fixed the errors
The disk-check utility does some "consistency" checks:
* every file listed in the the Table-Of-Contents actually exists on the disk-drive, with no exceptions,
* every file on the disk-drive is listed in the Table-Of-Contents, with no exceptions,
* every "block" of data on the disk is either "free", or used exactly _once_ by a specific file,
i.e., no block on the disk is unaccounted-for, and no block on the disk is "owned" by _more_ than one file.
The disk-check utility does _NOT_ read each "block" of data on the disk, to confirm that each block is "readable". Only when the file-backup attempts to read a file, does the inability to read that block get exposed.
Similarly, it's only when the file-backup utility is trying to write to one of the "free" blocks,
that the inability to write to that block get exposed.
So, what you need to do is to run the 'FORMAT' utility on the external disk-drive,
and to choose the "full" option, not the "quick-format" option.
The utility will try to write to each block on the disk.
When the utility detects a "bad" block, the utility will either flag that block as "never-to-be-used",
or the disk-drive itself will designate one of the "spare" blocks on the disk
as the permanent substitute for the "bad" block.
When the utility completes, it will either report the number of "bad" blocks,
or it will report ZERO "bad" blocks (because the drive's own electronic circuits
will have done that "substitution" in a "transparent" manner).
After the FORMAT completes, try your backup again. It should work.
Nov 03, 2010 | Toshiba Hard Drives
I can't backup files, because it says I have no more room. How can I fix this?
Delete some files or backups. If your backups are appending or creating a new file every time without replacing the old ones, it will eventually fill up.
If the drive is not full, it may be your file system. If the partition is formatted FAT32, you have a maximum file size of 4 GB. The backup will proceed until the file size reaches 4 GB, then it will close out and the rest of the files will not be backed up.
Using Disk Management, you can create a new partition, this tiime NTFS. Unfortunately, you'll lose all files on the drive when you partition so you'll need a place to move the files to temporarily.
Aug 08, 2009 | Seagate Maxtor OneTouch 4 500 GB USB Hard...
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My Book 1Tb will not let me copy movies on to it.
To transfer files larger than 4GB to the drive, the harddrive must have an NTFS File system. Unfortunately, the FAT32 File system is not capable of handling a single file larger than 4GB (to be exact, one byte less than 4GB). Follow the steps below to format the harddrive with an NTFS File system:
Warning, all data on the harddrive will be lost! Please backup the data on the harddrive before proceeding.
  1. Locate My Computer (Computer in Vista). Right-click on the harddrive and select Format.
  2. Select NTFS from the File system drop-down list.
  3. Select Quick Format as the Format option and click Start.
  4. Note: If NTFS is not an available option, close the Format window and follow steps 4-9.
  5. Right-click My Computer (Computer in Vista) and select Properties.
  6. Select the Hardware tab and click Device Manager.
  7. Expand Disk drives and right-click on the harddrive. Select Properties.
  8. Click on the Policies tab and select "Optimize for performance.”
  9. Click OK.
  10. Repeat steps 1-3.
Nov 28, 2008 | Western Digital My Book Essential Edition...
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Aluratek AHDU350500 500 GB USB 2.0 Hard Drive Logo
27 people viewed this question
Top Aluratek Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you an Aluratek Hard Drive Expert? Answer questions, earn points and help others
