Question about Sony STR-DG1000 7.1 Channels Receiver
Sony STR-DG1000 HDMI video not displayed
I am using a fairly new STR-DG1000 with two HDMI inputs - BluRay DVD and satellite box. I am sending video to the monitor using the HDMI out port. After several weeks of working beautifully, all of a sudden the video is gone, monitor indicates "No Signal" (but the sound running directly from receiver to speakers is still working fine). Can't find anything wrong - I do know the monitor is handling video directly from an XBOX 360 via component video just fine. Anyone have this sort of problem?
  • ghcolley Dec 27, 2007
    As noted in the original post, monitor works fine on direct component video connection to XBOX.
    Sergeant:
    Champion:
  • 209 Answers
That's strange, does the monitor work with regular av cables or and s-video cable ?
Posted on Dec 27, 2007
  • Simon Zwaan
    Simon Zwaan Dec 27, 2007
    Does your Dvd player also take the direct video cable as your Xbox ?, maybe try connecting your Dvd player a different way and figure out if it's the cable.
    Does your Hdmi only provide the picture or also the sound ?
Connecting a sony STR-KM7600 to a led tv
If you are using a cable box, then run your HDMI cord into your receiver HDMI input. Then another HDMI cord from thr Reciever HDMI out to your Samsung Hdmi input.
Apr 17, 2012 | Audio Players & Recorders
I need to hook up my Kenwood vr-207 to a satellite HD receiver and blue ray player. How do I hook up the component cables. I am not sure where to plug in the "in's" and "outs".
In's always go to Out's.
The VR207 has no component video inputs, just a composite video output so you can use your TV for the receiver's On Screen Display.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/vr207.pdf
Just run your BluRay and Cable box HiDef HDMI, component, s-video, composite video, whatever (in that order of preference) to a matching input on your TV or monitor.
As a rule you should run the best audio from each of your video sources to the VR. There is no compelling reason to ever send good audio or video to a device that has little (or no) use for it.
Unfortunately, the VR207 has no digital audio inputs, so the best it can muster regarding surround is Dolby Pro Logic derived from 2-channel inputs.
BUT, if you have a DVD, BLURAY player or cable Box with 5.1 analog outputs you can let their internal circuitry decode Dolby Digital programming to true 5.1 for input ("DVD/6CH") to the VR207.
Feb 05, 2011 | Kenwood VR-207 Receiver
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
I'm trying to hook up my reciever up to my new flat screen any help as far as what cables I need, I will also be putting a dvd player on as well. I have comcast cable also, I've been told I need to get a...
This is posted under the Sony STR-DE685 heading, so I assume that's what you have. (If not, your receiver may have other hookup options available.) It might help if you download the manual if you need a copy from Sony's site here. It details all the rear panel connections.
This receiver doesn't have HDMI connections, so you'll need to make your connections using RCA cables It doesn't pay you to get an HD cable box if you're planning on connecting it through the receiver.
Output to the TV is very simple. Use a component video cable to go from the component monitor output on the receiver to the TV's component input. Then switch the TV to that input, turn off its speakers and listen to the sound through the receiver. Only one cable going to the TV that way.
Inputs will need separate audio and video connections since there are no HDMI connectors. Use the component video connection for your DVD player for the best video quality. The DVD/LD input offers those jacks. You can connect your cable box to the VIDEO 2 input using component video connections (if the box has those outputs) or composite video. Then the video and audio from the box will run through the receiver as well.
If you want to get a new HD cable box, you'll need to run a cable from its HDMI output to an input on the TV, and switch the TV to that input to watch the box. You can still run the audio signal through the receiver though. That will add one more cable to your hookup, and you'll have to remember to switch inputs.
Hope this helps. Thanks for using Fixya!
Jan 26, 2010 | Sony STR-DE685 Receiver
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
Hi there I don'tseem to be getting any component video output. I am inputting virgin via optical input video 1, I get the sound and the box even displays virgin but no visual output?
Optical is for "audio only" you need to send Video from whatever source you are hooking up, ie. TV,DVD,DSS,etc. Use what the source has, if it's got Component Video out, use that, Don't use HDMI! still too many firmware issues! Make sure when you hook it up to the receiver that you hook it up to the same input as your audio, just on the video side. It will say DVD or DSS or CBL next to the green,blue,and red inputs. Hope this helps
Jun 21, 2009 | Sony STR-DG500 System
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
No Video or Audio on HDMI on Sony STR-DG800
The sony device may not be able to support the Toshiba. Make sure that is completely compatible and that you have the correct cables and setting to support everything.
Dec 31, 2008 | Sony STR-DG800 Receiver
Sony STR-DG1000 7.1 Channels Receiver Logo
240 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
