Question about Sony KP-57WS500 57" Rear Projection Television
BLUE CRT for Toshiba 57H84
My Blue CRT needs to be changed. I would like to do this on my own . Please help
    President:
  • 4,402 Answers
Why do you say that?
Posted on Jan 11, 2008
Have 57 " Toshiba projection TV there is way too much red in picture
TV has 3 CRTs, red, blue, green. Its possible that you have a bad blue or green crt. If that were the case the red would be prevalent and the pic would be reddish. The tv has a picture "level" adjustment that if done correctly could get it looking correct. Its probably best to have a tech. do it since you can make it worse if you do not know what you are doing, also there are high voltages present. Good luck
Oct 30, 2011 | Toshiba 57H84 57" Rear Projection...
My toshiba 57 inch rear projection tv every once in awhile makes a loud pop similar to a spark noise and the screen either goes black or flickers. do you have any suggestions what is causing this??
THis could be one of the CRTs (Color Tubes) is bad or the high voltage is leaking somewhere.
Toshiba projection TVs have history of yoke problems.
My guess is one of the CRTs is arcing inside. This TV has 3 CRTs red, green and blue. Replacing a CRT is not easy or cheap to buy if you can find it. If you like this try calling a TV technician to track down the high voltage arcing. DO NOT TRY TO DO THIS BY YOURSELF.
Best of luck my friend.
AAA TV SERVICE
Jun 12, 2011 | Toshiba 57H84 57" Rear Projection...
I just bought a used 57h84 and the pic is not real clear and dark and sometimes it seems to be alittle blue could it be the bulbs
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 23, 2011 | Toshiba 57H84 57" Rear Projection...
Toshiba 57h84 sounds like it is turning on but the only thing it is doing is the red light on the power button flashes no sound on picture nothing
CK your hori output Transistor and small blue capacitor round it feed the hori output 2k high voltage cap if they are OK then Replace both of your STK ICs they will have part number on them. For Parts Call Mats 1-800-628-1118
Dec 08, 2009 | Toshiba 57H84 57" Rear Projection...
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
Blue screen when watching tv
hi,
i contacted toshiba and this what they have recommended, i am concerned whether it will be cost effective to repair.
''The Blue CRT is being driven at maximum brightness, it could be
components in the associated drive circuitry or more likely an internal
Short circuit of the Blue CRT itself.
I have not rectified the problem but would be interested in the cost of repair if any can give me an idea
Hope this helps others as well
regards
chris
May 19, 2009 | Toshiba Televison & Video
SERVICE MANAUL FOR A 57H84 toshiba
Hi
Click on the following link: Click Here
Please remember to rate this solution as FixYa!
Kind regards
BearWeb
Apr 12, 2009 | Toshiba 57H84 57" Rear Projection...
Loss Of Blue Color
The loss of blue could be one of 3 things. First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables. Make sure the BLUE connection hasn't fallen out or is loose. The possibilities is the blue CRT (picture tube) itself or something in the blue CRT driving circuit.
Feb 25, 2007 | Toshiba 57H84 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
