Question about Sanyo DS27910 27" TV
Sanyo TV stretches outwards and shakes
This is a sanyo DS27910, 27 inch flat screen tube tv, I guess model 2001, the pictures is stretching outwards and back,in a shaking pattern, a punch in the back will fix it for 20-30m and then it starts again. I am good at soldering, I will like to try to fix it myself. Thanks
  • Anonymous Feb 01, 2008
    same problem screen is stretched out
  • 373 Answers
If the picture is closing (top to bottom) and goes back to normal when you hit it you probably have a bad solder connection on IC501 (location number) the vertical deflection IC on a metal heat sink. If you mean outwards as in side to side as it looks in the picture, I don't know specifically where to solder but get a magnifying glass and look for suspected bad solder connections. Look for the word width if it is there. It is good that you a confident in soldering.
Posted on Dec 30, 2007
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
Picture tube for sanyo flat screen tv
You've got the BRAND, now we need the MODEL and NUMBER!
And maybe an actual question would be nice!
There are a few "flat" tube TV's but very few that were made several years ago. The vast majority of flat screen TV's don't have a picture tube.
If the screen is physically broken on your flat screen TV it's probably not worth the cost of having it fixed. If it's not physically broken, something else might be wrong.
Nov 09, 2016 | Sanyo Televison & Video
I HAV a 58 inch Sanyo tv DP58D33 and my screen is black but when I flash a flashlight in a dark room while is on I can see the TV displays. What should I change to fix problem
a model 58D33 is a LCD screen not to be confused with an LED tv , aas LCD tv displays use a std fluorescent tube for its back lite source and yes they do burn out eventually , unfortunately these tubes are not a user changeable item and tv needs to be disassembled to install a new one
Nov 13, 2015 | Sanyo Televison & Video
Sanyo 2008 flat screen 42 inch no picture have sound
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sanyo 42K40 42 inch Multi-System LCD TV
Just bought a Sanyo 32 in tv. When I play DVDs, it stretches the picture, which is already widescreen and 'letterboxes' it, leaving black strips top and bottom of the screen. Anyone know how to fix...
Usually to change the video format of your tv you will find it in the remote control try to look for format button in your remote there you can change the different aspect ratio of your video format settings. hope this help good day and best regards.
Sep 24, 2011 | Sanyo 42 in. LCD TV
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
My sanyo hdtv plasma won't show the whole picture but it worked fine yesterday
Hi my name is Roety,
I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
1.Format
2.Aspect
3.Size
4.Zoom
5.Wide
6.#
First look on the TV remote, set it to Full ,Fill or Just or 16 x 9 (whichever your model uses) Samsung uses the P size button ,
Then on the cable/dish Box remote stretch (not zoom) is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom/size button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Stretch will fill the screen and allow you to read the bottom.
Make sure you are on the correct input, sometimes TVs are connected on multiple inputs
(not necessary, only the HD input is needed)
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 15, 2009 | Sanyo DP50747 50 in. Plasma TV
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Xbox 360 stretched screen out and cannot fix it now
Have you checked the aspect ratio?? May be that when the kids had the X-Box hooked up they simply changed the aspect to zoom.
May 22, 2007 | Sanyo DS20425 20" TV
Sanyo DS27910 27" TV Logo
365 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
