Question about Samsung DVD-P241 DVD Player
Technical support needed can't get player to eject disc
DVD Player DVD-P241
  • Tarhillbilly Jan 05, 2008
    We cannot get a disk to play or eject.  It just shows as "loading" with no video play.  Please help
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Posted on Jan 05, 2008
I unscrewed 3 black screws on the rear side, removed upper panel and realized that disc was shifted a little from the center. So I move it to the center position with fingers so it could be easily rotated with finger. Then put upper panel back. Good luck.
Posted on Sep 23, 2009
The laser lens is dirty preventing the disk from loading. Clean the lens with a cleaning disk available from any electronics store. To open the tray use the manual eject button with a paper clip. If it doesn't have one then tun the player off then back on and hit the eject button while the player is booting. This might take a few times to get the timing of turning unit on and hitting the eject button to get it to work.
Posted on Mar 23, 2008
Hook-up to a SonyKDL-32L4000?
Posted on Feb 08, 2009
How do I open the player to remove a DVD?
The DVD may have gotten jammed if the player was dropped or shocked with it inside. In this case, disassembly may be required to remove it. Sometimes the ejection mechanism becomes weak or the tray starts to bind. Recently, I had a Zenith player on the bench with just such a problem. When a DVD was placed in the tray, it required a gentle nudge to close. Even cleaning and dry-lubing the rails did not help.
Jul 29, 2015 | Samsung Model Dvd-p241 Multimedia...
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 19, 2011 | Samsung DVD-P241 DVD Player
The disc is stuck and it won't open
Your only real choice is to bring it in for service. You don't want to damage anything by pulling it open, if the disc is really stuck, the player needs to be taken apart to get it out without damaging the dvd player.
Feb 06, 2010 | Samsung DVD-P241 DVD Player
Wont eject dvd
Pull out the power plug leave it out for a while and then put it back in and then hold open/eject button until the DVD player says open/eject let go..the DVD tray should come out.
Please vote if this helps..thankyou!
Aug 13, 2009 | Samsung DVD-P241 DVD Player
Region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
Can't open dvd drawer
try putting a Blunt knife into the top of the dvd drawer, or where you can get a knife in.
And gently prise the drawer open whilst pressing eject on the Player.
Failing this, you will have to *****disconnect from the mains***** remove the screws on the rear of the casing, remove the top cover, and take out the DVD Disk.
Replace then plug back in, to check if the player is Ok.
**** Only remove the casing if you feel competant**** And if the player has no guarantee Or Warranty****
Mike @ Compurepair.
Jun 12, 2009 | Samsung DVD-P241 DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
DVD Freeze-Ups
Sounds like the transverse motor is bad.
Dec 03, 2007 | Samsung DVD-P241 DVD Player
Video on P241 DVD player
replace the bigger IC of the module
Oct 23, 2007 | Samsung DVD-P241 DVD Player
Samsung DVD-P241 DVD Player Logo
656 people viewed this question
Jerry Greenberg
Jerry Greenberg
