Kenmore Elite HE3 Steam? 8674 Dryer
Problem for Kenmore Elite HE3 Steam? 8674 Dryer
I have a Kenmore Elite HE3 dryer model #
By fawnperry on Oct 13, 2009
I have a Kenmore Elite HE3 dryer model # 110.8483220. It has no power. We tested the plug and it tests for 110V of power, and the wire connection at the top of the dryer (on the outside) has power. But there are no lights on the display and no interior light when the door is opened. Any ideas of what it could be?
Solution #1
posted on Oct 13, 2009
Not Rated)
vladimir77
Rank: Guru
Rating: 94%, 40 votes
Your dryer is electric. This means it needs 2 electrical phases (hot wires) and one neutral to wor. If you measure 110v across 2 phases - one of them is out.
Unplug the dryer. Find the double breaker for your dryer on the breaker panel.
Pull breaker to the off position hard (do not overdo it,as you can pull the breaker out), and then back to on position.
Check voltage between the two phases, it should read 220-240v. Check the voltage between each phase and the neutral (middle prong), should read 110-120v. If you don't get these readings - call electrician.
If you get the proper voltage, plug the dryer back in. If it does not work - Dryer needs repair. Likely a thermal fuse is blown or problem with power wiring inside.
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite HE3 Steam? 8674
Questions and Unsolved Problems for Kenmore Elite HE3 Steam? 8674
Do you recommend Kenmore Elite HE3 Steam? 8674 Dryer?
Answer
Answer
Kenmore Elite He3 Model #11092824100 Dryer is no longer heating. Checked vent for airflow , good... (More)
Answer
Our Kenmore Elite he5 steam dryer has an error message F01. Can you help?
Answer
I have a Kenmore HE3 - 82824102. No lights on control panel but interior light comes on when you... (More)
Answer
my dryer keeps getting a PF code and will not come on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore Elite HE3 Steam? 8674...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14896
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
