McCulloch FHH18A 1800 Psi, 1.45 Gpm Electric Pressure Washer With All Purpose Wand
Problem for McCulloch FHH18A 1800 Psi, 1.45 Gpm Electric Pressure...
Switch prblem
By jackson_hugh on Oct 13, 2009
switch problem after pressing the resett button the unit still does not work
Best Solution
posted on Oct 14, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 8028 votes
hello sir, to get your manual and parts for your McCulloch chain saw,. trimmers,power washers, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw, or trimmer, to be e - mailed to you for FREE. hope this helps,MrFixIt,oh could you please rate this solution,thank you$$$
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for McCulloch FHH18A 1800 Psi,
Questions and Unsolved Problems for McCulloch FHH18A 1800 Psi,
Do you recommend McCulloch FHH18A 1800 Psi, 1.45 Gpm Electric Pressure Washer With All Purpose Wand?
Answer
Answer
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal... (More)
Answer
Cannot start Homelite 7 HP EX21 gas pressure washer. Not sure how to set the primer lever? Forgot to... (More)
Answer
When the power switch is first turned on it makes a repeating loud noise until the water trigger is... (More)
Answer
karcher K2.91 will not switch on unless you start on low pressure adjustable detergent lance had... (More)
Answer
I just purchaced a FAIP replacement pressure washer pump model no. PMP10247 and would like to... (More)
Describe your Pressure Washers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pressure Washer Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
