Question about Fans
Holmes HASF-99 10-Inch Velocity Blizzard Stand Fan needs reipair
Hi there! We have Holmes HASF-9 10 inch Velocity Blizzard Stand Fan. One of my son's birthday balloons got sucked into it and the streamer ribbons is wrapped around the blades and motor. We can find no way of getting the front or back off to remove the ribbon. Is there anyway to do this without damaging the fan. There seems to be no screws to remove, it seems like it is just glued on. Any help would be greatly appreciated. Thank you.
  • 44 Answers
Re: Holmes HASF-99 10-Inch Velocity Blizzard Stand Fan...
I downloaded the owners manual from but did not see how to undo the grill. However if you go to (the fans official site) you should be able to ask them on what to do.
Posted on Feb 09, 2008
0 characters
3 Points
I need A 9 inch fan blade for my Massey fan 9
Did you contact the manufacturer or manufacture's fan replacement parts center?
If you're thinking of having one made, I'm sure it would be far cheaper to replace the entire thing, (or maybe find a similar fan and use its blades so they are more balanced).
Or try ebay.
Sep 25, 2014 | Fans
Why is my Holmes HASF-1710 not getting power
This may be a duplicate post but here's my advice. Do a little disassembly to get to the "guts" of the fan. It is not uncommon for the speed control switch to break in such a way as to not allow the circuit to be completed. You may have to actually remove the switch and inspect it to be sure of this. I've had trouble finding replacement switches so I have put them back together with superglue. If this is your problem and you choose to use this solution just be sure all the switch parts get put back where they belong. If this is not your problem, break out the ohm meter and start checking your connections. Hope this helps
Jul 06, 2014 | Holmes Products HASF1516 Stand (Pedestal)...
How do I get the housing off my Holmes hasf 1301 fan?
try turning it counter clockwise no need to be gentle.
Apr 09, 2014 | Oasis Hunter 54' Ceiling Fan
Since Lakewood doesn't make fans any longer, any idea where I could pick up a couple of their 9-inch high velocity fans (new or used)?
Hi randy r metc...
I found one 9" High Velocity fan on ebay, it is new at a cost of $19.99 and free shipping.
Please take time to rate me
To see the fan go to the following webpage
Aug 18, 2011 | Lakewood High Velocity Fan 9 Inch
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
I just bought a Holmes 16 inch stand fan HSF1610A I only use it to sleep. Only have had it for about 2-3 weeks. I have not had a problem with it til I woke up this morning to it not working. It still...
First smell the fan, If you get burning smell then you need to send it for warranty repairs or to a repair shop. If no burning smell then check the electric cable for connectivity. Most probably it has gone bad and it's easy to repair. For checking it you need a electrical tester or multimeter.
May 02, 2011 | Holmes Products Holmes& Standing Fan
I have a holmes blizzard fan and need to clean the blade. how do i take the front cover off
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
Jun 30, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Fan turns very slowly for a few seconds and then stops
it may have pulled in some hair around the shaft. disassemble and clean
Jun 24, 2009 | Holmes Products HAPF622R Floor / Box Fan
Fans Logo
863 people viewed this question
Top Fans Experts
Barrett Palumbo
Barrett Palumbo
Are you a Fan Expert? Answer questions, earn points and help others
