Question about Toshiba 32HL95 32 in. LCD TV/HD Combo
LCD TV REPAIR
I, bumped the screen with a package. It now has a spider web pattern at the point of impact, and lines going Horiz. and Vert. across the screen. From the impact point. Can it be repaired?
  • channyc Aug 05, 2008
    i have a spot on my t.v that is colored and has a glowy affect to it and the colors look florescent it looks almost like a paint splash and when the t.v is off u can still see the spot
  • 3 Answers
I will buy this broken tv from provided everything else works ... I am looking for the 32hl66 model
if this is what you have please contact me at vtcpuguy at yahoo dot com
Posted on Sep 19, 2008
    Problem Solver:
  • 8 Answers
Physical damage is probably not covered under warranty - check your owner's manual and call customer service - they will advise you [dxh]
Posted on Dec 27, 2007
Spider webs behind screen
Pardon me but do you mean the screen has spider web looking patterns all over it? Or are you saying that spiders have crawled into your set and spun webs to catch flies?
If you have a spider web pattern problem then something has impacted your television screen and it is broken. You can check and see if your homeowner's insurance covers this, contact a service provider to see if they want to buy the television for its parts, and contact Mitsubishi to see if they offer a discount or pro rated rate on a new or refurbished television for when things like this happen.
If the problem is that you have spiders in your television I do not recommend vacuuming it out. I have seen people's televisions go out after they attempt to remove dust and webs that way. In this instance I also recommend contacting a servicer and the manufacturer.
Jan 28, 2011 | Toshiba 57HX83 57" Rear Projection...
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
Lines on the screen regardless of the input source. I replaced the bulb and still have the same problem...
One of the 3 lcd's has bad bad pixel drivers...lines could be
horiz or vert...need to reolace the lcd..
Art
Jul 04, 2010 | Panasonic PT-AE900U Multimedia Projector
3 year old threw drumstick, and hit the screen small spider web at impact point and vertical colored lines lenght of screen
Unfortunately he has damaged the screen, the only way to fix this is to have the screen replaced, this can cost almost the price of a new TV. If you have home contents insurance you could possible put in a claim for accidental damage.
Jun 24, 2009 | Sony BRAVIA KDL-46V3000 Television
Spider-like lines run all over screen from impact point
Sounds like a broken display
the only way to fix this problem is replacing the LCD panel
Sorry to tell you that!!
Apr 20, 2009 | Samsung LN32A330 32 in. LCD TV
Horizontal Line Across the screen
Your Zen got bashed. or at least the screen suffered some violent movement and shifted on its moorings. To make it simple... all around the perimeter of the LCD screen, there are electrical contacts for HORIZ and VERT signals which come thru tiny ribbon cable (looks like copper colored ribbon but actually is flat mylar with wire laminations inside) anyway, these are either socketed, soldered or have pressure contacts which make the connection and give you colors in the right places. The connector for an entire HORIZ row came loose, got bent or broke. The only fix is to locate it and either resolder it (difficult without a 'needlepoint soldering iron), reshape that single contact so the right part of the display (HORIZ connection cable) touches its pad again, or replace the display,, socket, or its cabling. I have one with bad HDD but everything else is OK (Display too) which I can sell you cheap. All you'd have to do is pull your HDD, install it in my old Zen, and go.
PM me if you are interested: somethingscrooked@uku.co.uk.
Nov 17, 2008 | Creative Labs Zen Digital Media Player
I have a 1983 popeye arcade machine. the circut board that controls the vert hold for the monitor has 4 knobs for vert., sound, horiz., and bright. thevert. hold knob is busted off and the screen has...
VR353 is a 200k pot that feeds directly in to the vertical oscillation input of the chip on the main board at connection B1. If this pot is broken, you must replace the pot in order to get any vertical oscillation at all.
Sep 10, 2008 | X-Gaming X-Arcade PC Joystick (XGMPC)
Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
312 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
