Question about Samsung MW1030WA Microwave Oven
Samsung microwave When I start my under the counter microwave a light flashes under it? Is this dangerous? What could it be? Max joelkessler@hotmail.com 810 695-4952
    Master:
  • 619 Answers
Leaking of current , the door isolation current are leak need to replace non conductor material
Posted on Jan 03, 2008
I don't have a dedicated circuit for a only microwave oven use only. Is this necessary?
no
microwave ovens are a plug -in unit and be plugged into any socket (GPO outlet) that has the correct voltage for the unit
Jan 04, 2017 | Microwave Ovens
Microwave interferes with TV
Take one fluorescent light-bulb -- not connected to anything -- and a darkened room. Start the microwave, and see if any emissions from it activate any of the fluorescent materials inside the light-bulb.
Mar 15, 2014 | GE JVM1653 Microwave Oven
Panasonic microwave works but have to lightly tap the top of the door to make it work. Sometimes it works normally, but sometimes after the time is set, and the start button is pushed, it waits for about...
Troubleshooting your Panasonic microwave oven requires removal of the cover. There may be a loose or broken connection inside. Be sure to read and heed the dangerous voltage warning. As for the repair or replace issue, that depends on age (in appliance years) and whether parts cost and labor are reasonable.
Dec 12, 2013 | Microwave Ovens
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
Light bulb not working on my ge microwave model JVM1870SK03
Replace the light bulb, if that is not enough , check contact to lamp holder.
If microwave is not working at all, check also door switch , fuse, and control panel.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Feb 23, 2009 | Danby DMW1153 Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Samsung MW1030WA Microwave Oven Logo
248 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
