RCA Home Theater Model RTD215
Front and center speakers are loud, but the two rear speakers are almost unable to be heard. I went into speaker setup and tried to adjust the volume but was unable to adjust just two speakers.
Cox digetal cable universal remote will not work with this system now i have 3 remotes for tv,cable, and now my home theature system
Posted on Feb 17, 2008
We are working with a yamaha HTR-6240. The memory guard is locked on and we wont to use auto setup. Also, as it is currently set, we are getting a lot of volume from our rear speakers and very little...
The manual is available at retrevo.com
Page 43:
Under Setup / Memory Guard on/off
For volume of individual speakers see Speaker Setup (Auto) or (Manual) on page 39.
Dec 23, 2010 | Yamaha Audio Players & Recorders
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Rear speakers dont seem to be loud. The front speakers are projecting most of the sound. How do I get the rear speakers to project more sound?
Your settings in the receiver are not set up properly.
You need to adjust the volume output through the rear channels in your receiver.  Review you manual for set up. The issue is in the receiver, not your speakers most likely
Sep 24, 2009 | Coby CSP-94 Speaker
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
Speaker Problems
push the "sound edit" button on the remote, it will bring up things like, bass, center spkr, rear spkrs.. change the volume control on the rear spkrs.
Apr 09, 2009 | Samsung YP-U3 MP3 Player
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
I have a RX-V461 AV Receiver for my Samsung HDTV.
I don't have manual here, but try to go to Setup menu / Speaker setup / Manual Setup / Config and check if rear speakers are NOT set to None.
Nov 19, 2008 | Yamaha RX-V461 AV Receiver
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
Can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Dec 05, 2006 | Dell PART NUMBER KIT SPEAKER MM ACS45...
Televison & Video Logo
680 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
