Question about Microsoft Windows Vista Ultimate Edition
Sound driver in need
I wiped my comp completely had xp but then downloaded vista need a sound driver how do i download a driver to a disc and if its a dvd or cd disc that i need and what download site to get it from Please help
    Problem Solver:
  • 18 Answers
First you will need to find out what sound card you have. if it is a computer you bought in store. than should be able to get it from there official website. example dell/ if you have sony than it would be if you don't have a brand computer. you will need to know which company is your sound card. and than search the companies card on or after you have gotten the driver you will need to burn the driver to a disc. a regular cd would work fine. i would recommend a flash drive. it is much easier and much faster.
i hope this helps.
Posted on Dec 27, 2007
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Nov 03, 2009 | HP Business Notebook 550
Can't find disc
I suggest emailing lexmark and telling them u need a disc for a Lexmark X2550 printer. Maybe tell em yours didnt come with one when u bought it and be firm...or you can continue to try and download it from the internet.
Aug 23, 2009 | Lexmark X2550 All-In-One Printer
Reinstalled xp after Vista . USB port not working
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Dec 19, 2008 | Computers & Internet
I having hp comp it was having Windows vista but now i change in Windows xp is having a problem of sound i need the driver of sound for this comp hp 530
Sep 11, 2008 | HP 530i (Q6750A) DVD±RW Dual Layer...
My optiplex gx260
first of all u need one oparting system cd. windows xp or windows vista.put cd in cd rom and boot your pc from cd dvd in first screen booting options. then make partitions install step by step OS. when u complete go to dell web page search your computer model for download drivers for your oprating system like sound driver display driver modem and all hadwares.
now your computer is ready for use.
Sep 04, 2008 | Dell OptiPlex GX260 PC Desktop
Reinstalled windows xp profesional after hd crash. Did not have the original acer aspie 5100 recovery disc to install. Now the cd dvd rom is not recognised by laptop
if you originally had Vista on then the bios is updated from the older XP bios and wont see the drive, check here for bios downloads, or put Vista back on.
If you have a full XP disc you will need to do a full format and installation, do not use somebody elses restore disc as it's not the complete windows that you will need.
Aug 31, 2008 | Acer Computers & Internet
Lg super multi dvd multi
You can download the windows driver here.
I says, it is for all windows, but I don't know if it is also suitable for Vista.
You didn't tell me your operating system..
May 24, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
Wiped hard disk
Windows XP and Vista should have most of the drivers for the operating system to load. If any are missing after that and your internet connection is ethernet, then you should be able to get the rest of the drivers free from the samsung home site to make your laptop run properly.
Jan 06, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
