Question about KitchenAid KSB5 Professional Stainless Steel Work Top Blender
Blender blinks My blender goes crazy after a few seconds of use, the "on" and the other button blinks, after I pressed on any of the five speed.Can you help?
  • ptazo80 Oct 05, 2008
    I am having the same problem. I was using my blender all summer for frozen drinks-- one day it was blending for about 5 sec and then all of the button lights started blinking/flashing and the blender stopped altogether. I'm able to blend a little longer w/out it stopping if I use the pulse mode, but eventually it stops and starts blinking again.
    Problem Solver:
  • 9 Answers
Need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Posted on Nov 03, 2008
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the...
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Jan 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Blender has lost top two speeds
With my blender, some of the buttons stopped working, and I found a simple way that fixed it like new, with no special skills or replacement of parts. To determine if this fix will work for you, unplug the blender and press on each button. As you do this feel and listen for a definite 'click'. If you here it for the buttons that are working, and not for those that aren't, you probably have the same problem.
I discovered that there is a tiny mechanical push button switch under each button. The switches are held snug to the bottom of each button by a thin metal bracket. If you have heavy fingers, the force of pressing the buttons over time, causes the bracket to deform, moving the switches further and further away from the buttons until, eventually, no matter how hard you press, they are no longer close enough to depress the switches underneath.
The solution is to simply open the blender (with the power cord removed) and gently push the button assembly back towards the buttons. To get inside you need to pull out each of the four rubber feet, and unscrew the phillips head screws that are hidden under them. Next, seperate the top and bottom sections by gently pulling the power cord through the strain-relief (don't worry, it goes back together very easily). Before putting it back together, check the buttons (always with the power cored unplugged !!!) for the 'click'. If this doesn't work, you may have to take out the two screws that fasten the bracket to the blender, and bend the bracket hold-down tabs with a plier, in the opposite direction of the switches (that way when you put the screws back in, they'll move towards the buttons. That's it.
Hope this helps someone like me save about $150.00 for a new one and keep another 10lbs. of junk out of the landfill.
Nov 08, 2008 | KitchenAid KSB5 Ultra Power Work Top...
amy, my new mixer won't turn on either. If you get some help please let me know. Thanks
Oct 02, 2007 | Jenn-Air JBL800SS Work Top Blender
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
348 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
