Ecoquest Fresh Air Air Purifier
Problem for Ecoquest Fresh Air Air Purifier
My fresh aire eco quest will not turn on. checked
By conniesweil on Oct 13, 2009
my fresh aire eco quest will not turn on. checked fuse its fine. LCD panel was fading for last week. now will not turn on at all.
Solution #1
posted on Oct 19, 2009
Not Rated)
MrsRDC
Rank: Apprentice
Rating: 100%, 1 votes
Check the wiring connections - there is also a green broad 'band' that connects the LCD screen. Make sure that it is plugged in. Will be hard to reach - use gentle needle nose pliers if it is hard to reach. U may need to wrap the insides to make sure that you don't harm the harness. Also ck to make sure that all electrical wires are connected securely. I am just an owner of 3 who has taken them all apart to fix them.
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Air
Questions and Unsolved Problems for Ecoquest Fresh Air Air
Do you recommend Ecoquest Fresh Air Air Purifier?
Answer
Answer
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi... (More)
Answer
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest... (More)
Answer
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the... (More)
Answer
install plate? no i just cleaned and now it won't work. it says to install plate.
Answer
unit cut off about every 2 minent then come back on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Fresh Air Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2540
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
