The service mode can be accessed but there are two different ways of entering/exiting the service mode and it depends on what type of microprocessor is used. Usually a special type of remote is required to enter the service mode on this TV.
However you can try the following;
1) Using your current remote control press "Menu" followed by 9301 and this should take you to service mode.
2) If this fails use either an old Philips remote or a Universal remote that has a contrast button. Press contrast + & - together simultaneously to enter the service mode on the TV.
3) Simultaneously press chanel + and - on local tv panel and then power on with main switch
Please be aware
Entering or making changes in servicing mode menu / service mode entry data by untrained persons can cause significant and permanent damaged to your television system. If you are not qualified to repair it then it is advisable to call a Service Center.
my beko tv just wont turn on i was using it yesterday and it has just packed in i have changed the...
(More)
my beko tv just wont turn on i was using it yesterday and it has just packed in i have changed the plug fuse and thereis no fuse inside the back.please help!!??
i having been playing my game and took the scart out and the tv went black with noi channels from av...
(More)
i having been playing my game and took the scart out and the tv went black with noi channels from av to 5 what has happend and how do i fix it
My beko tv has a system setting on BG. I need to change it to L but it won't change. How do I change...
(More)
My beko tv has a system setting on BG. I need to change it to L but it won't change. How do I change the system setting?
