Question about Toshiba TE2100 Notebook
Boot error, won't even boot with xp cd - Toshiba TE2100 Notebook
  • majjo Dec 27, 2007
    thanks for trying, but can't get past advanced options menu. bluescreens in all modes. trying to boot of windows xp proffesional upgrade cd/dvd without success. how can I check harddisk?
    Problem Solver:
  • 18 Answers
Hi.
you might wanna check if your XP is a dvd or cd. if it is a dvd your cd drive can not read dvd cd's. if it is a cd than your cd/dvd drive is not working. another thing you can do is to take out your cd/dvd drive and plug it back in. to see if it works. if the drive is working, you can try a different XP CD to see if it is working. if it is still doing the same thing. you might wanna check your hard drive to see if it works.
hope that helps.
thanks.
Posted on Dec 27, 2007
HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Nov 28, 2012 | Computers & Internet
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
Windows xp won`t boot up. Get error messages services.exe and Lsass.exe and screen goes black...thank you....
Unfortunately, Lsass.exe is the security policy manager for Windows XP. You only options will be to try and press F8, and choose "Last Known Good Configuration." If that doesn't work, you will need a Windows XP CD. Enter that into the drive and boot to the CD. Go to Repair (not Recover Console). This will rebuild Windows XP, and keep your data intact.
Good luck, and I hope this helps somewhat!
Oct 21, 2009 | Dell Latitude C610 Notebook
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
Getting ERROR FOR OPERATING SYSTEM
This is because you have to change the boot sequence in the BIOS or setup of the motherboard. When you first turn on the computer you can see something like press DEL to enter Setup or F12 or F10 or F2 depending onyour motherboard. once you get into setup you will see either boot sequence or boot order. Set the CDROM as the first boot device. Then when you startup the computer again you will see PRESS ANY KEY TO BOOT FROM CD. proceed with pressing anything on the keyboard.
Installing XP on a toshiba satellite l45 s7424 laptop
Boot your computer from your xp intallation cd, windows xp will install alright.
May 28, 2008 | Microsoft Windows XP Home Edition
Toshiba TE2100 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
