Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
The control panel works but when you set the bake temp the display indicated "pre-heat" but we get no heat. Had to get through Christmas without the oven. :(
  • 4 more comments
  • Keith McDonald Dec 31, 2007
    How do find the reset button? my convection oven worked one day won't the next,the service man was here 2 r 3 years ago and ''hit the reset button'' and it worked till now.Where is it ?I have flipped the brakers and nothing is wrong at the elec.Thanks
  • paul-slocum Jan 29, 2009
    will not heat
  • alyce1154 Feb 02, 2009
    The control panel lights up but the lower burner does not heat. The broiler unit does, however
  • Anonymous Mar 21, 2014
    Panel will not respond afterwards until range shut off at fuse box and turned back up.
  • Anonymous Mar 24, 2014
    No error codes,control panel works normal but no heat on any setting
  • Anonymous Mar 31, 2014
    Broiler works but oven won't heat to temp. Also very slowly heats up
    President:
  • 1,314 Answers
Reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
Bake Element
I would start by checking the temp sensor of the bake temp settings. Pull it and its most likely bad your thermostat control, also did you ohm out the element before installing it i have bought many new bad ones as well. anything else just ask.
Apr 05, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Nov 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
My Jenn Air oven W27200B displays F2 error any solutions? Also one of the burners would hang- one worked and the other didnt.
HI. this is a failed oven temp sensor or relay board.
Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
Ohm test the oven temperature sensor, if OK, change power relay board.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
My Jenn Air Electric Wall Oven Control panel lights have gone out
You will need to replace the display assbly.
It is a very common problem with maytag/Jenn Air
Feb 19, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
1,175 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
