Question about Refrigerators
Improper installation of kenmore refrig.
In our new home the plumbers installed a Kenmore Elete side-by-side. The next morning there was a leak from apparently the icemaker ruining the new wooden floor. The Sears man said it was not their fault but that the water line was not bled free of air by the plumber causing the leak.(All connections tight). My contractor says that is bull and a ploy by sears to avoid paying for the damages, and that line bleeding is not necessary since any Tom Dick or Harry can do the installation and not that complicated. What do you all think.
Mark Allen,
  • 362 Answers
Re: Improper installation of kenmore refrig.
Actually not bleeding the line can cause leakage on some models and yours is one of them, you need to have a heart to heart with the installer. not every one can install water to an icemaker. your owners manual should have the warning in it.
Posted on Dec 27, 2007
0 characters
3 Points
HOW DO i GET my new refrig to stop rollng forward. It is a kenmore elete trio
make sure the floor is level and not slanted toward the front u can take the lil kickplate off of the front and put something in front of the wheels to stop it
Mar 01, 2010 | Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Water is leaking from freezer into lower compartment of kenmore
If you think it is the ice maker then shut down the water supply and see if the leak stops. Most likely though it is probably a blocked defrost drain.
Apr 09, 2009 | Refrigerators
Installing the water filter to my refrigator
Rotate the cartridge hand hold to a vertical position and PULL.
You may need to get pliers to grab with.
Jan 21, 2009 | Kenmore 53642 / 53644 Side by Side...
Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Kenmore side by side refrig model 52514100
water on the floor this morning. freezer not frozen
Aug 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
