sorry for my english. my router losts internet connection frequently. when it happens all lights are on but there is no signal. I have to turn off and turn on the router.what I have to do to solve this problem?
Please first check if your router are on master socket or not.In case it is not then please shifted to master socket. It might be possible that your secondary socket not getting the proper signal.First check with that. In case you still loose connection.Get to your ISP ask them to run a line test on your line.They will give more explanation on this,then.
Hope first solution itself will resolve your issue.
Was this helpful?
Yes
No
Popular Solutions for Zyxel Prestige 660HW Wireless
Hi... I wanted to setup my (borrowed from someone) P-660HW modem and it kept asking me the 3 things:...
(More)
Hi... I wanted to setup my (borrowed from someone) P-660HW modem and it kept asking me the 3 things: system password, username, password... I pressed the reset button so the it turns back to factory default settings...but after that its not turning on :( The handbook says... the power light will blink on power on... and then become steady...instead it blinks on power on and then goes off :( Any bright ideas ???
I upgrade the Firmware of Zyexel 660hW after that i was waiting for the device to boot back ....
(More)
I upgrade the Firmware of Zyexel 660hW after that i was waiting for the device to boot back . unfortunately it didn't reboot, i Did a physical reboot after that it no longer working only the power led is flashing
i still cannot remote cctv even i input ip on default server in NAT. can u help me ? i use Zyxel...
(More)
i still cannot remote cctv even i input ip on default server in NAT. can u help me ? i use Zyxel Prestige 600 series
I'm not able to go wireless with my Macbook (I am able to connect via hardwire). My modem is a zyxel...
(More)
I'm not able to go wireless with my Macbook (I am able to connect via hardwire). My modem is a zyxel 660HW - T3 kevin
I want to use the address "localhost" for testing web pages. However localhost is blocked...
(More)
I want to use the address "localhost" for testing web pages. However localhost is blocked despite of 127.0.0.1 is incribed in the hostsfolder. I can ping my PC but I cannot connect using the telnet option. However I can open with telnet the Prestige Menue. I suppose I have to configure something there to enable loopback.
In fact I am using Zyxel Prestige 660WH Wireless Router! Please apologize this error.Gakusei
