I do not have a remote, I have a universal remote but the codes I have do not work. The picture is in Black and White and it rolls.I do not have a remote, I have a universal remote but the codes I have do not work. The picture is in Black and White and it rolls.
There is a ntsc/pal botton on your remote press that and it sould go back to normal if its not onthe remote try to go in the settings and it will ce in there someware
Check the video setting in the set-up menu. It may be set to PAL if you are on the NTSC system, or vice versa. Also check the TV input to ensure your're on the correct channel.
there is a ntsc/pal botton on your remote press that and it sould go back to normal if its not onthe remote try to go in the settings and it will ce in there someware
if your cable box is digital it should have the yellow, white, red rca jacks in the back run those to the rear a/v input on your recorder then cycle through the input switch on the remote until you see the picture. (i have the same model i hope you have better luck with yours...i can't record on any new 4x or slower +rw disc i had mine since 2006 i should've got a sony!)
In black and white? If there is a red and yellow, white and yellow, or red white and yellow on the tv end make sure the colors are matched correctly. Try on channel 3. Try on another tv. Is the camera from a foreign country? (Might be PAL, not NTSC.) If so, there should region menu in the camera to change this. For video, you have to shoot it in the mode of the TV you want to watch it on. North American TV's are NTSC, so shoot with the camera in that mode. If you shoot in PAL mode, a north american TV will show a black and white rolling picture. Just about everywhere else in the world is some version of PAL.
I have the same problem. Can't stop the picture from rolling
