Question about Onkyo TX-DS474 Receiver
Onkyo TX-DS474 has no center speaker or surround speaker output
All the other speaker and line outputs work fine. I have followed the programming and troubleshooting instructions in the Instruction Manual and also did the microprocessor reset procedure from the service manual. I reseated all the pcb connectors and tested the speaker driver transistors for opens, shorts, and cracked solder. The customer said those outputs had been working and stopped. I am testing with my own speakers. Is there a history of this problem on this model? The way the unit is made, it will be a big job to get everything in a position where I can follow all the control and signal information with a scope.
  • Jerry S Jul 08, 2008
    I had found a defective logic transistor that was used to drive the output select relays and that fixed that particular problem.
  • 682 Answers
1-speaker cable is not connected.
2-surround mode button is set to stereo.
3-center level is set to minimum.
4-center speaker is set to no.
Posted on Jul 07, 2008
Onkyo tx-ds 474
press and hold the video 1 button and then press the speaker A button - you should see 'clear' on the display. This will reset everything
Jul 14, 2014 | Onkyo TX-DS474 Receiver
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I just bought an Onkyo tx-s804 receiver. and some new rear surrounds. Since I am moving, have not set up anything formally, but have plugged my dvd player into the front video 4 input via an optical...
PCM is what it's receiving from the DVD player. The player has output bitstream settings, too, maybe even speaker configurations and distances. Read its manual.
May 11, 2011 | Onkyo TX-SR804 7.1 Channels Receiver
I can't figure out what output to hook my Mirage nanoset 5.1 sub woofer up to.
There should be a purple colored RCA jack on the unit's rear.
This is the output to the sub.
Link to owner's manual:
Mar 25, 2011 | Onkyo TX-DS474 Receiver
I am using an Onkyo TX-8255 receiver with the ION Profile Pro USB Turntable and I'm hearing distortion through my speakers at all volumes. The speakers and the receiver work fine with the radio and the...
The TT should be connected properly for the way it's configured (Line Level Out to any Line Level In OR Phono Out to Phono In) and NOT any other way.
Some background reading:
Jan 15, 2011 | Onkyo TX-DS474 Receiver
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
Sound disappears when channel is changed
try connect a rca cables to ensure sound , the tv has scart port or audio output rca? the digital input on receiver is non priority level, so every time you change chanell the receiver jumps to next Line input present. (receiver output security)
Jan 17, 2010 | Onkyo TX-DS474 Receiver
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Onkyo TX-DS474 Receiver Logo
220 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
