Question about Apple iPod nano
Ipod nano 3rd gen
Hiya i got a ipod nano 3rd gen and the computor is reconizing it as a usb 2.0 (hs) flash disk usb device when i plug it in and itunes is not reconizing it i be greatfull if you could help
    President:
  • 317 Answers
It's in disk mode and the computer thinks that it is only a storage device. You need to reset it to get it back to normal.
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Dec 27, 2007
SOURCE:
When I try to download music from pc to my ipod, pc says connect
Hmmmm check wit the data cable once.. try using different USB ports els different data cables itself..
- if cable workin fine den try doin a hard reset.. i.e with d iPod plugged in 2 d comp try resetting iPod..
-Els check if ya iPodz getting recognized in iTunes.. if itz gettin not gettin recognized reinstall the itunes software.. or follow dese steps-
1>www.apple.com
2>Click on the tab SUPPORT
3>Select iPod+iTunes
4>Select iPod nano 4 r 5th gen
5>U'l find many divisions as get started troubleshooting n al.. under troubleshooting d 3rd link i.e iPOD DOESNT APPEAR IN ITUNES n follow d steps
-if itz gettin recognized in iTunes n not gettin recognized in comp den follow d same steps til troubleshooting.. under dis go to d 4th link i.e iPod is not recognized properly by computer when USB drivers are not installed properly r out f date..
Try wit al dese steps.. hope sumthin works out 4 u..
If none f dese work den derz another step to it.. may b disk mode step which am not sure f.. try finding out regardin diskmode n may b dat'l help ya..
May 26, 2010 | Apple iPod nano
I have an ipod nano 3rd generation and it won't unlock
1. Plug the ipod USB cable into the bottom of the iPod Nano.
2. Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
3. Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
4. Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
5. Click on the "Sync" button to establish a connection between your iPod and the computer.
6. Click on the eject symbol next to your iPod's name after the syncing process has finished.
7. Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
Sep 24, 2009 | Apple iPod nano 3rd Generation
Ipod Nano gen 3. Won't work unless into charger or dock
Hi! Try uninstalling the itunes and reinstall it after restarting your PC. If it doesn't help then try to install a diffrent version of itunes.
Dec 26, 2008 | Apple iPod nano 3rd Generation
Ipod usb help
im not for shure what OS you are running but with XP and newer it should read it. try downloading itunes
Nov 13, 2008 | Apple iPod nano 3rd Generation
Ipod nano 3rd generation wont connect with windows xp
I have the same ipod and had the same problem - I ignored itunes and the computer and went to "real player" and treated it like an mp3 player and in real player you pick your music you want to burn to a cd but go to "device" column and change the destination from burning to your internal cd burner to the external drive which is the ipod and it downloaded perfect! hope this helps
Sep 11, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod nano 3rd gen
have you tryed the 5 solutions?
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
does the ipod power up when you connect it to the charger and does it turn off and wont turn on when you unplug it?
May 07, 2008 | Apple iPod nano 3rd Generation
Ipod nano 3rd generation not recognised by computor
Right-click on your desktop, then click the Advanced tab. Then you should see on the lower left where it says screen resolution. Set this to 1024x768. This will allow you to see the setup assistant.
Dec 27, 2007 | Apple iPod nano
You can only sync an ipod with itunes software, it doesn't come with the ipod though.
Go here:
http://www.apple.com/itunes/
On the right hand side it says itunes 7 Download now. That's the software you need to use with an ipod.
Dec 25, 2007 | Apple iPod nano
Ipod not recognized by computer or itunes
I struggled with this issue for a while and finally found a post that helped me. Hold menu and the center buttons until the iPod turns off. Then, immediately hold the left and center buttons to pull up the iPod diagnostic menu. Scroll down to the option "Reset" and select it. My iPod was finally recognized by iTunes. Good luck :)
Nov 20, 2007 | Apple iPod nano
Apple iPod nano Logo
105 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
