How do i replace headlight bulb on an electrolux epic
To be honest, It's simpler to take it to any vac shop to replace at a nominal cost than it is to explain how to through all of the steps to do so yourself but I'll try. Basically, remove 6-7 screws from the bottom of the nozzle head, take a medium flat bladed screwdriver and gently pry back on two accessible internal tabs in the bottom rear of the nozzle head in order to pop the top of the power head off. Remove the top and there you'll see how easy it is to change. You can use a 15W or 25W bulb. Reassemble and VOILA! You're back in the spotlight! Hope it helps!
