Question about Ricoh Aficio CL2000N Laser Printer
"Load paper" When print command is clicked, a redlight in the middle comes with a message "load papers". How can you fix this situation. It used to work without this sign before.
  • rsohn42 Dec 29, 2007
    I checked the paper tray. Rearrnaged the papers. Filled to the almost to the top. The same condition remains. Now, what else?
    Where is the sensor located? Is there anything you can do restore the sensor and check on it?
    President:
  • 1,944 Answers
Try to check your paper tray and feeder. Make sure everything is aligned properly and there are no foreign objects (such as dust or paper) that could interfere with paper feeding process.
Posted on Dec 27, 2007
  • Damen Wong
    Damen Wong Dec 28, 2007
    Is it ok now?
  • Damen Wong
    Damen Wong Dec 29, 2007
    Under the SmartDeviceMonitor, what does it say about the paper tray?
    Guru:
  • 1,894 Answers
Hey not a big problem. its usually encountered by many users.
i too get this many times.
this happens when you keep papers freshly.
it needs to sense the papers kept.
now what you do is just keep more papers or try re-aligning the papers kept inside
  • 6 more comments
  • dewan nafees ahmed Dec 27, 2007
    actually there is a sensor that detects the papers once they are loaded. in some printers it wont detect the papers once we keep it. even tough papers are there in tray it wont detect it. just trying keeping papers in different positions. it will detect it.
    advice would be always keep papers in reserve in the printer. dont let it make empty
  • dewan nafees ahmed Dec 28, 2007
    even if different positions dont work out see if there is any obstacle in the\at makes the sensor not reachable to paper... it may be like fust or somethin.. u will have to clean it..
    even after this its not detecting means please tell me..
    paper drawer is completely full... no printing happens..
    Trying to print documents - responce reads "load manual feeder with plain paper letter"
    ..if this is the problem solution is as follows..
    The printer may be trying to draw paper from a source other than the
    paper tray. Many printers have a hatch or slot in the front or on the
    side in which one can load non-standard paper sizes and envelopes. It
    may be trying to print there. Try to locate this place and put a few
    pieces of paper in there.
  • dewan nafees ahmed Dec 29, 2007
    paper drawer is completely full... no printing happens..right..
    solution:
    if the paper is not detected itself then sensor must be bad..
    sensor will be located near the edge of the slot where you input your papers..
    this model uses a LED to transmit a light through a little section of
    the empty toner cart. Its a little square area and should be located on
    the backside of the empty toner cart. you will see the sensor that it
    slides into. Make sure this area is clean.If this area is dirty you
    will still have a error light.
    my best guess would be there was spillage of toner on the sensors to
    detect the waste basket overflowing, hence why the error message is
    constant. This would require cleaning of the sensors, a relatively
    simple task but for proper access, the machine would need to be
    partially disassembles for thorough cleaning. It would be best done at
    a repair centre.
    See your manual:http://www.ricoh-usa.com/downloads/manua...
    page 22 of that manual wll help you i think..
    see to it and reply me
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
I'm using CANON LBP 3300 Printer...When I load Legal paper in Cassette , it's asking to load in manual slot.. Please help
When I print any document the printer prints on the right side
of the paper and would like to know how to set the page to
print on the middle of the paper.
Sep 16, 2010 | Canon LASER SHOT LBP 3300 Printer
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
Getting message to load tray 1 A4. load with
This problem is commonly found across printers, and is not specific to your printer model.
This problem occurs if:
  • You select the Hold mismatched documents option on the Advanced tab of the Properties windows of the printer.
  • The printer driver user interface (UI) plug-in uses the full UI replacement functionality. This means that printer driver replaces the default Windows printer dialog interface, so Windows fails to find certain registry keys to determine the paper type.
Microsoft has a hotfix for this issue for Vista and Windows Server 2008:
http://support.microsoft.com/kb/971319
If you are seeing this issue on XP, you can do the following:
1. Go to Printers and Faxes from the Start Menu (or type the following command in the Start->Run window: control printers).
2. Right click on the affected printer's icon, and click on Properties.
3. Click on the Advanced tab.
4. Uncheck the option Hold mismatched documents.
5. Some printers have the default paper type as Letter, so please change the printer properties to use A4 as the default
5. Click OK to save the settings change.
6. Wait for 15 seconds, and try to restart your printer job if needed. Usually, Windows will automatically restart the job, once the paper mismatch setting is resolved.
7. Ensure that you make the above printer property settings change on every computer where your printer is installed.
Happy printing!
Jan 21, 2010 | Dell 5110cn Laser Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Jul 30, 2008 | Dell 3000cn Laser Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
147 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
