LG 32LC7D Television
Problem for LG 32LC7D Television
My TV turns on with a alot of colored vertical
By rmi3 on Oct 13, 2009
My TV turns on with a alot of colored vertical lines. After it is on for about 15 minutes, you can turn it off and then back on and everything is okay. What is wrong with it?
Solution #1
posted on Oct 13, 2009
Somewhat Helpful)
MNfisherman
Rank: Wiz  LG Televisions & Videos  Expert
Rating: 85%, 2828 votes
convergance issue. Possibly bad high voltage transformer or a bad capaictor or IC or STK depending on what type of tv you have. If projection, then STK, if lcd or plasma, then it is an IC
Was this helpful?
Yes
No
Solution #2
posted on Oct 22, 2009
Not Rated)
Chu3505
Rank: Guru  LG Televisions & Videos  Expert
Rating: 85%, 522 votes
Take the backcover off turn it on take back side of the screw driver tap it around see where the colors flicker u know which boards cause that prob.15 mins turn off back on it ok,a intermittant prob.that the best way to solved it,u can change the bad board after that.
Was this helpful?
Yes
No
Popular Solutions for LG 32LC7D Television
Questions and Unsolved Problems for LG 32LC7D Television
Do you recommend LG 32LC7D Television?
Answer
Answer
how can i get a better picture quality on my new 37 in lg model 37lh20
Answer
lg 32lc7d lcd i get red and green blinking light on startup then colored vertical lines on screen... (More)
Answer
need lg 32lc7d tv code to program philipsvz144p2 remote control
Answer
the cable remote stopped working got new ones and still same problem any ideas why
Answer
Power goes out and cant turn unit back on. Green light continuously blinks then after a day or two... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
