Question about Apex Digital AT2002S 20" TV
Apex tv 2024
I would like to know if this model of standard tv will be compatible with cable’s HD boxes. Time Warner is asking to swap out regular cable boxes to HD cable boxes. Will connecting the new HD box to the TV work?
    President:
  • 3,130 Answers
As long as the New Cable boxes have an analog output they will work fine.
Posted on Mar 07, 2008
How do I connect my time warner box to the dtv input on my 2001 MITSUBISHI 1080P HD TV
You need the proper cables. I would call your local cable office and ask them. You will need the model # off your TV. 2001 mitsubishi 1080P HD TV is not the model. The model will start with VS. It is located on the rear of the TV.
Feb 28, 2015 | Mitsubishi Televison & Video
Just bought a new Panasonic TC-L42U22, connected it to a samsung time warner HD cable box via HDMI, but the cable remote is not working. There's picture and sound, but can't turn it on or off, change the...
You have to program the remote to work with your specific model tv. If it still doesnt work after that call your cable provider and ask them for another remote.
Mar 24, 2011 | Panasonic TCL42U22 42 in. TV
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
I have Time Warner cable. I just bought a new Sony LCD HD tv and the sound and the video are out of sync on some channels - HD and non HD I am using a HDMI cable. Any solutions that you know of?
Yes there is a simple solution. First, for some reason., Time Warner cable boxes have SERIOUS HDMI issues, including no pic, intermittent pic and sound and the one that you are having. The easy fix is to hook the TV to the cable box using the component connections instead of the HDMI. Normally I would suggest getting the cable box replaced, but I have seen customers exchange cable boxes 3 or 4 times and still have the problem or have a new problem. Use the component connections and be sure to let me know if this works. If it does, be sure to rate this solution. Thanks!
Nov 09, 2008 | Televison & Video
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Apex Digital AT2002S 20" TV Logo
71 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
