Downtown off sixth street. Just kidding. This set has an a/c power supply located outside the wooden frame that secures the main and deflection circuit boards. Very seldom does this cause a problem though. The most common problem in my experience is convergence failure. Testing this is easy. The convergence board is seperate and is mounted above the others. Small pcb with large heatsink. Removing the blue wires with the red plug(I think it's a 5 pin plug) should restore power if set is in shutdown due to that failure. Then you can just try to replace that board if avail. Next problem on this set is coolant can start leaking from the tubes and go onto the circuit boards. Use a bright light and a good pair of eyes to examine the board closely, looking beneath the picture tubes for moisture or drops or corrosion on boards. Please make sure tv is disconnected from power source while testing and good luck, Russmann.
Was this helpful?
Yes
No
Popular Solutions for Akai PT4298HD Rear Projection
I have ragged dark (but not opaque) line down the left side of the screen that gets wider, then...
(More)
I have ragged dark (but not opaque) line down the left side of the screen that gets wider, then narrows, then widens again. The rest of the screen is fine, image quality in HD is great. Just can't figure this out. 42 in. AKAI DLP HDTV bought in '05.
keeps shutting off after 30 seconds first the picture will go out, then the sound, and then the unit...
(More)
keeps shutting off after 30 seconds first the picture will go out, then the sound, and then the unit shuts off
I just inherited a PT4298HD Akai television I plugged in and all i get is the red light blinking. I...
(More)
I just inherited a PT4298HD Akai television I plugged in and all i get is the red light blinking. I was wondering if it is worth repairing. If it is can you give me diagrams of what to look at?
