Question about Cuisinart DLC-5 Food Processor
Stuck dough blade
I can not remove the dough blade in my cuiinart food processor. It is stuck!
  • chartsg Aug 16, 2008
    One shredding job. Stuck. Discovered that if I replaced the bowl on the base, suddenly the disc came off easily.
    Did another shredding job; disc stuck, really stuck. I can['t budge it!
  • greendork Dec 19, 2008
    I solved the stuck blade by putting a pair of channel lock pliers on the plastic blade tube with the machine on the floor held down by my wife. Gentle rocking of the blade tube
    and pulling up strongly separated it. But resuming kneading a fairly heavy dough, caused the blade assembly to jump up again but not stick. Do we need a new shaft or blade or both?
Not a solution, merely more of the same
I had my shredder stick on; unplugged, reassembled the bowl on the base, and it got loose.
Did another shredding job, and now it's really stuck.
Any ideas, PLEASE
Posted on Aug 16, 2008
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Posted on Apr 05, 2008
How do I get a dough blade for kitchenAid food processor Model 4KFP 600 WH
Kitchen Aid list them, it's on this page called blade, dough
http://www.kitchenaidpartsonline.com/modellookup/index/thirdstep/keyword/KFP600/model_no/KFP600WH/model_id/398686/diagram_id/10083552
Feb 24, 2015 | KitchenAid Food Processors
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
My 12 cup kitchen aid food processor dough blade is seriously stuck inside the bowl after I made some dough. How do I get it out?
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Sep 17, 2009 | KitchenAid Food Processors
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
Kneading blade stuck
plz contact 022-23051554 /23095757
Feb 02, 2009 | KitchenAid KFP750 Food Processor
Dough hook stuck
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Sep 05, 2008 | Magimix 5100 Cuisine Systeme Food...
Making Dough
Yes, it is the S-blade. I can't find my manual either and I have been trying to figure out how to get it onto the shaft!! The Hamilton Beach website says it should slip down the shaft once the bowl is attached, but I have a white piece on top of the metal I can not remove and the s-blade will not slip over it.
Dec 03, 2007 | Hamilton Beach Chefprep 70700 Food...
Cuisinart DLC-5 Food Processor Logo
1,288 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
