Question about Toshiba TZ50V51 50" Rear Projection Television
Convergence problems my toshiba tv has a red ghost starting at the bottom up to midpoint of the screen and also another one in the upper right hand corner, i have went to the convergence menu and my crosshairs will not line up red and blue on all numbers. some numbers will line up to where there is only the white crosshair but others aren't even close. i'm no electronics whiz but i was wondering if there was anything i could do to fix the problem with the right guidance
    Problem Solver:
  • 18 Answers
Well I would say the convergence amps are the culpits in your case. A common problem with all rear projection sets these days. Be real careful about buying replacements as I would go OEM only. They sell counterfits and low cost knock offs that will just frustrate you and raise the chances of damaging the board.
Posted on Dec 27, 2007
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Samsung PCL541R 54" Rear Projection...
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
Toshiba 43HX70 convergence problem
One or both of the STK convergence chips have probably failed.
I can give you guidance on this if you are confident to do the repair. I had the same problem with my Tosh 40WH08B and after replacing these chips it works like new.
May 21, 2009 | Toshiba Televison & Video
Sony Bravia KDF-50E2010 LCD Convergence Problem
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone hope this works davy mac
Dec 21, 2008 | Sony Televison & Video
Panasonic projection tv
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Red Ghost
This may be a convergence issue but it is difficult to determine with that description. Watch this video and see if it will help you determine if you have a convergence problem or possible something else.
Aug 10, 2008 | Toshiba 57H82 57" Rear Projection...
Wavy lines / red ghosting
Sounds like your convergence amps need to be replaced (STKs). I am not sure what the rates are in your area, but typically you're looking at around $200 or so.
Jun 07, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Philips 32PW9536 Screen distorted to the right hand side
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 03, 2007 | Philips 32PW9523CG 32" TV
Weird convergence
The convergence IC's are the culprit. Its a common fault still for as long as I can remeber projection tvs. Even the front projection types had convergence problems when the manufacturers switched from discret componets to Integrated circuit. Most sets have two IC's some have three. Its always better to change all the IC's at once, as the problem will occour on the others a time down the road, and more labor involved. A typical convergence repair is around 300 or so. Its not a consumer replaceable part unless you have the experience with soldering and know the issues related to the Hi Voltage and safty involved with the serviceing of these sets. Good Luck
Jun 15, 2006 | Toshiba 46H83 46" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
