Question about Olympus FE-210 Digital Camera
Memory XD picture card not recognized
Put two different memory cards in camera one was an Olympus brand, one Fuji Xd Picture card. Neither one showed up as being recognized. Both cards are good because they work in my other Olympus camera.
  • 852 Answers
SOURCE: Move images to the internal memory to the optional xD-Picture Card?
The images saved to the internal memory can be copied to the memory card, but you cannot copy images from the memory card to the internal memory.
Posted on Aug 31, 2005
  • 852 Answers
SOURCE: Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD-Picture Card, but you cannot copy images from the xD-Picture Card to the internal memory.
  • 479 Answers
SOURCE: Memory Card Error
either the card is bad or corrupted... try cleaning the contacts on the card, then try to format thru the camera menu
Posted on Sep 24, 2008
SOURCE: New memory card
Hi I have bought a new memory card, Olympus XD M 1GB. For my Fuji fine pix A330 camera, and I can't get it to initialise, or format properly, can you help me many thanks TRENA
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: Fuji xd memory card
I had same problem especially in flash mode. I changed SD Memory card and it is now 100% good. You must always use Premier brand cards, cause others may cause problems. You must als format your card first, before changing it.
Posted on Feb 01, 2009
  • 919 Answers
SOURCE: My new memory card will not work for the Olympus Camedia D-560
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Posted on Apr 06, 2009
0 characters
1 Points
Card not initialized?
The error can be caused by:
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130)
To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
If the message still appears, replace the xD-Picture Card
for 3.: You won't like this one:
Contact your FUJIFILM dealer.
Oct 30, 2013 | Fuji FinePix S6500 Digital Camera
I keep getting the error card not recognized when trying to use an Olympus M+ xd 2gb memory card. How large of a memory card will this camera support?
From what i know and i own a Fuji FinePixA360.According to the Manual 1gb is the highest amount of memory listed.Also you can not put a M+ (high speed) card in the camera will read error.Bascially the Fuji is an older camera and was designed for 1gb and must use the "M" xd picture card (DPC-M1GB) .Thats all the higher memory that was available when the camera was manufactured.I don't know if a 2 gb memory card will work but if you do try one make sure its the older M NOT M+.Hope this helps someone,Gary Malcontent
Sep 20, 2009 | Fuji FinePix A360 Digital Camera
Picture card 16MB
Your Oly uses xD memory which is made by Fuji and others but apparently your camera is limited to 512MB cards so check with any supplier to ensure you are not buying something you cannot use.
Here is one source of many:
Olympus xD memory
Nov 16, 2008 | Olympus Camedia C-160 Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Memory card
it will work just fine! a xd card is a xd card-olympus only brands the card to make a few bucks off it-they are usually made by pny or sandisk.
Jul 10, 2008 | Fuji FinePix Z5fd Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
Memory Cards Compatibility
As long as it's an XD-picture card, any brand should work.
Sep 12, 2005 | Fuji FinePix S5000 Digital Camera
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Olympus FE-210 Digital Camera Logo
302 people viewed this question
Top Olympus Digital Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Digital Camera Expert? Answer questions, earn points and help others
