Question about Philips 55PP9352 55" Projection Television
PROJECTION TV unlock convergence code with remote control for 55pp935217
    Problem Solver:
  • 18 Answers
Why do you want to get into the service mode of your set. If you don't have the service manual with all the factory presets you can do more harm than good. I say this because if you were a technician you wouldn't be asking for this information. If the convergence can't be adjusted from the customer menu then you have parts problems that should be addressed by a service technician.
Posted on Dec 27, 2007
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
Model 55PP935217 multiple convergence mode, the blue colored + is pulsing after IC chips #7044 and #7045 were properly replaced and resistors (12) were good. When single convergence mode is selected, the...
I understand your frustrations, and if you did the work yourself you can feel really bad. In this case if you really want to save this TV, I would suggest you visit Union Electronics. And purchase a reworked replacement board. In many cases this is the best route to go and the price is reasonable. Call them at 1 800 648 6657. I have had very good luck with this company! And these boards are guaranteed, ask for the lenghth allowed. Have your TV model # and tell them you are looking for the convergence board. Thanks for asking!
Aug 08, 2010 | Philips 55PP9352 55" Projection Television
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
Oct 06, 2009 | Philips 55PP9363 55" Rear Projection...
Philips Projection TV the colors are separated- not converging
This was hapening to me too. To fix I just punched the tv. If this works then some wires were disconnected. Punch the right and left side not the screen or the back it will damage!
Apr 07, 2009 | Philips Televison & Video
Phillips hd tv
convergence i.c.s change both of them even if only one color is out. if one is bad the other is usually going to give out soon. the part # should be. stk 392-120. also check resistors around i.c.s if the open you wont be able to adjust convergence.
Mar 20, 2009 | Philips 55PP9352 55" Projection Television
How do i realine the bulb in my samsung rear projection tv
use you're remote to enter code mute 183 while tv is on then press 7 for red 8 for green and 9 for blue control. arrows or knobbie will move cursor. if you still can not control the red you will need to change the red convergence ic...press perfect focus to save changes if pf is not on remote maybe on tv if neither you will need to get a remote that has it to save info.
Jan 27, 2009 | Samsung HCM4215W 42" Rear Projection...
Corner convergence for panasonic pt51hx40c projection tv
Yes there is a Service Code you need in order to set convergence and on this set it is not easy to enter! 1) Switch Antenna to cable (2) Set Sleep Timer to 30 mins,Exit menu Enter ch 124 (3) Now Press vol- on front of TV / A red CHK should appear on screen / NOW enter menu and turn sleep timer off / Exit again,now Press Power untill you see 0V00 press ch up untill you see 0V1 Then Press vol+ you should now have convergence Pattern on screen. To adjust use (ch- ch+ and vol- vol+) (cursor) moves to where you want to adjust (mute) locks place you want to adjust RTune changes R-G-B when done make sure you Save adjustments.
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
55pp935217 Way too much blue
No sounds like the blue CRTs coolant has congealed and thats whats giving you the trouble. the blue tube get congealed and will cause the blue to not even show up properly in the convergence menu
May 18, 2008 | Philips 55PP9352 55" Projection Television
Philips 55PP9352 55" Projection Television Logo
325 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
