Question about iLO DVDRH04 DVD Recorder
Copying 8mm tapes to dvd
I am needing to copy my 8mm camcorder tapes to the ilo dvd recorder so my tapes can be on DVD. I have tried to connect the cables many ways and can not get it to work.
  • 3 Answers
Try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Posted on Jan 26, 2008
I have Panasonic NV-DS99 and need to copy the movies from the tapes 8mm to my computer , How can I do it ? and what devices or cables I need ? Thank you for your help
Easiest way is to get stand alone dvd burner. You could use the Dvdirect from Sony. You plug in the camera into the recorder hit play on the camera then record on the burner. That is the easiest way to transfer tape to dvd. Then your able to put it on your hard drives. Hope this helps.
May 29, 2011 | Panasonic NV-DS99EN Mini DV Digital...
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Dvd recorder has copy protected message
the tapes that you can,t copy are protected, manufacturers used to put a high pitched frequency on the tapes themselves, which would in theory cause a scrambled frequency. the only suggestion i have for you, is to play the tape onto a television, and use a camcorder to record the image from tv to camcorder, then camcorder to pc, and use some good editing software to create the dvd.
alternatively, you could try using a second dvd player, and use your recorder as the second device.
The final but more expensive option, is to look for a way to input the recorder, direct to PC. which you would use picture out, to graphics card input, and the red and white ( Audio ) for the stereo Sound output. does your player or tv have An spdif connection or similar, you may be able to output to camera, rather than to dvd.
Where theres a will, theres a way, but these are a few options.
****Please note:- this information is supplied only as you have the original Movies***
Bear in mind, it is illegal to copy protected content. However as you own the originals, this information is provided to enable you, to backup your Purchased Content.
Thankyou for using fixya.
Mike @ compurepair.
Jun 15, 2009 | JVC DR-MV100B DVD Recorder/VCR
I have a sharp camcorder model vl-e785u and I am needing to know if there is somehow to download my tapes to a computer to burn to a cd.
I don't know about downloading to a computer, but you can buy a VCR/DVD recorder for about $140, put the VHS-C cartridge in the adapter and transfer to a DVD, or plug your Camcorder into a DVD recorder (about $119) and copy. It couldn't hurt to check out some of the transfer services that could do a little editing and copying for a modest fee.
Mar 01, 2009 | Sharp VL-E785U 8mm Analog Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Multi-function DVD recorder VRD-MC5
Update to my 1/8/08 posting - my recorder is working perfectly! I found the installation of the needed file quite easy and all is good in the hood.
Later
Nov 10, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
iLO DVDRH04 DVD Recorder Logo
189 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
