A loud screeching sound from your dryer could be caused by a few different issues. Here are a few things you can check:
Belt: A worn or broken belt can cause a loud screeching sound. To check this, unplug the dryer and remove the front panel. Look for any signs of wear or damage to the belt. If it looks worn or broken, you'll need to replace it.
Drum Rollers: Dryer drum rollers can also cause a loud screeching noise. You can check this by turning the drum by hand. If it feels rough or wobbles, the rollers may be worn and need to be replaced.
Idler Pulley: A faulty idler pulley can cause a screeching noise. You can check this by removing the belt and spinning the pulley by hand. If it feels rough or wobbles, it may need to be replaced.
Motor: A motor that is failing can also cause a loud screeching noise. You can check this by turning the drum by hand and listening for any unusual sounds coming from the motor.
If you're not comfortable checking these components yourself, it's best to call a professional to diagnose and repair the issue.
Is it squeeling or a sound like metal to metal as if it squeels, then perhaps your alternator is getting bad or your serp belt, if its the other than perhaps your clutch maybe going start with the clutch flywheel hope that helps
Could just be a worn belt or faulty or loose tensioner. Does it only make noise when AC compressor kicks in? If it's not a metallic sound, and sound more like a screech/squeel, then I'd look close at belt condition, and tension.
Actually, it sounds like you have two problems. The belt and the bearing. The squelling is probably the belt but the screeching is probably the bearing and was the original problem that caused the belt problem.
It could be bearing or guides in the drum.Go to
http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/
This forum will work you through your problem
Sounds like you have a dryer drum belt that's getting bad. Once the belt gets warm enough, it becomes more soft and pliable, lessening the noise. Needs to be replaced. Hope this helped!
